Installing Headers 84 T/A 305--Hooker 2055's
Old Aug 25, 2006 | 08:19 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
How much of a pain is this going to be? I swapped the headers in my 67 Camaro but I didn't have cool things like A/C, power steering, or the Smog Pump. I could drop them right in. Can I do that with these or do I have to do something crazy like tilt the motor or remove my A/C accumulator? I hope it's just a simple weekend job but...hehe good thing we just bought a new truck huh?
Old Aug 25, 2006 | 08:30 PM
johnnyboy's Avatar
Car: '82 formula clone, 95 saab 900se
Engine: 350 vortec'd tbi, 2.0L turbo
Transmission: 700r4, 5 spd
Axle/Gears: 10 bolt 2.77 open
it will take you a full day. i just spent all day today working on my exhaust on my 89 formula it is a P.I.T.A. although you don't have to worry about snapping studs off of the manifolds. i've never done it before so i don't know for sure but it will be hard to get to the bolts on the manifolds to take them off of the heads
Old Aug 25, 2006 | 09:07 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Well, I will plan a full day then. I was just reading some of the topics I cound under the search function and some seemed to help. Seems to me that the passenger side will be the toughest. No access to a lift here, but 4 jack stands should work ok I think. The garage here wants $275.00 to install them for me. I'm not too keen on spending that kind of money on something I should be able to do myself. Provided I don't snap off a bolt while doing it.
Old Aug 25, 2006 | 09:10 PM
johnnyboy's Avatar
i would think that a bit of driving around before starting would help to get those bolts nice and worm kinda like the effect that using a torch on an old bolt has in aiding to remove it. good luck and yeah the passenger side is a royal pain to access when you have ac!
Old Aug 29, 2006 | 09:53 PM
84L69TA's Avatar
Car: 4 Mopars total
Engine: Pentastar power
Transmission: T/F and New Process
Axle/Gears: Three 8 3/4's & one 9 1/4
Any shorty header install Ive ever done on a thirdgen (ive done 6 of them), has NEVER taken me more than 2 hours...start to finish. And Ive never had to lift or tilt the motor. This was with Edelbrock TES, Hedman, and SLP.
Old Aug 29, 2006 | 10:08 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Agreed.. My Hedmans took about an hour to install, and the only disassembly needed was the removal of the DS valve cover, and the #5 ans #7 spark plugs.
Frozer!!!
Jan 19, 2024 04:55 PM
demontransam89
Wheels and Tires
Dec 28, 2015 06:58 AM
Akinnepa
Convertibles
Aug 26, 2015 10:54 AM
theurge
Aug 21, 2015 12:46 PM
drathaar907
Aug 6, 2015 04:20 PM
