muffler question
Old Sep 1, 2006 | 09:37 PM
dwillis's Avatar
Car: 1991 Trans Am Convertible
Axle/Gears: 3:08
muffler question
I'm about to do a dual exhaust setup on my 92...305....T-5....What would be the best muffler size wise to put under it so they don't drag...and where...I thought about right under the seat...or do some round ones along the side...Hell I dont know...Oh the car is stock height and will stay that way...Thanks...Dave
Old Sep 1, 2006 | 10:48 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
look in the dual exhaust thread sticky
Old Sep 2, 2006 | 09:05 AM
dwillis's Avatar
Axle/Gears: 3:08
Alright thanks...I must have overlooked that one...sorry
Old Sep 2, 2006 | 08:14 PM
xpndbl3's Avatar
Car: 1984 Z28
no biggie, people run flowmasters to spintechs to bullet race mufflers, etc. I'm swapping on turbo mufflers on my combo since my moroso spiralflows were too loud for the neighbors liking.
Old Sep 2, 2006 | 08:46 PM
dwillis's Avatar
Axle/Gears: 3:08
I'm not gonna be running big HP so I really like the dual 2 1/2" pipes run in the factory location and maby I can exit where the stock muffler does with something....I want it to be quiet cause I'm gonna try to do electronic cutouts on my shortys...if I can....
Old Sep 3, 2006 | 10:41 AM
ZimGTA's Avatar
Car: 88 GTA
Engine: 383
Transmission: 700 r
There are also 3.5" and 4" singles that will give you the flow that you need, and fit waaaay better.
Old Sep 3, 2006 | 11:32 AM
Rickj350RS's Avatar
Car: '90 Camaro RS
Engine: Aluminum Brodix-block SB 427
Transmission: Turbo 400
Axle/Gears: Moser 33 Spline 4:10
I ran dual 3'' spintech oval tube into two basically flat spintech circle track mufflers. I had it dump right before the rear end. If you want the exhaust to extend all the way to the tips, you will have to run both pipes over the rear end on the passenger side or get a panhard relocation kit. That will bring the panhard bar down low enough that it won't smash the pipe when the suspension bottoms out. The pipes from spintech are pretty pricey, but I love the look of the oval tube. Plus on cars that weren't made to have duals, ground clearance is everything. The sound difference from a single pipe to duals was like night and day. Unfortunately, the single pipe has almost a glasspack sound. The duals completely clean up the exhaust tone. When I first had the exhaust system built, I ran dual 3'' round tubing with two Super 40 Series Flowmasters. I reason I switched is because I hit a pothole and ripped one of the mufflers off. The 40 Series are something like 5'' thick compared to the Spintech mufflers which are only 3'' thick. I also like the way the Spintechs sound compared to the Flowmasters.
Frozer!!!
Jan 19, 2024 04:55 PM
formula_novice
Sep 5, 2015 03:58 AM
Thirdgen89GTA
Aug 20, 2015 12:11 PM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
