long tubes on a lowered car..can it be done?
Old Sep 5, 2006 | 06:03 AM
Wishmaster's87IROC's Avatar
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
I want to run long tubes but my car is lowered...can it be done without a lot of ground clearance problems?....or do I have to run shorties?
Old Sep 5, 2006 | 06:09 AM
84ZMIKE's Avatar
Car: 84Z28
Engine: 0.030 over 10.25:1 dart heads 350
Transmission: T 5 W.C. now
Axle/Gears: 3.73:1
You "could" run headmans as they tuck up nicely....the hookers hang a little bit lower,and since you have an auto the headmans "should "fit alot better....I can take a pic. of my headmans from the passenger side and show you the grownd clearance.
Good luck,
Mike
Old Sep 5, 2006 | 06:17 AM
yeah do that for me...I was just about to edit and say that Ive heard that headmans provide better clearance than hookers...do you have 1 3/4's thats what I need...also what kind of y-pipe or pipes did you run after the headers?...do they follow the same route as the stock pipes?
thanks for the fast reply
also what is the part number of the headmans?
Old Sep 5, 2006 | 06:37 AM
84ZMIKE's Avatar
Car: 84Z28
Axle/Gears: 3.73:1
The headman part number is 68460 .As far as pipes/ ypipe....no way could you run them in the stock location....my exhaust is "underconstruction".I'll put up a pick in a few min.
Mike
Old Sep 6, 2006 | 05:59 AM
are those 1 3/4 headers? where did you get them? how much? thanks
Old Sep 6, 2006 | 11:52 AM
heat seeker's Avatar
Car: 89 Formula
Engine: 383 SBC/HSR
Here are some pics of my exhaust, my car is lowered in the front, and yes it can be done. It just depends on how much you drive over uneven ground.
exhaust pic1
exhaust pic2
side pic of car
Old Sep 6, 2006 | 12:27 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
i've got shorties but my y-pipe simulates having long tubes.
I don't like it since it is very very low to the ground since the y-pipe goes under the crossmember. i've got less than 3" of ground clearance.
i'll snap a few pics as soon as the weather clears up.
Old Sep 6, 2006 | 10:29 PM
84ZMIKE's Avatar
Car: 84Z28
Axle/Gears: 3.73:1
I got them from a member here......you can pick up a set from Summit for around $135.
Old Sep 7, 2006 | 01:10 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Hedman 68460s are 1 5/8" primaries.
I don't think it's going to make a difference to ground clearance whether you use Hedmans or Hookers. The lowest part of the exhaust is usually where it goes under the frame rails or the transmission crossmember, not at the collectors.
Old Sep 7, 2006 | 07:22 AM
dennisbernal91z's Avatar
Car: Building LS3, T56 Z28
Engine: LS3
Axle/Gears: Moser/ 4.11
That is very true Apeiron. Problems arise at the x-member, not the collector so much.
heat seeker, you are running the exact same setup as me. Looks like you have dynomax bullet 4" mufflers on turndowns. That is what I have. Mine is 3" made with all mandrel bends. Looks like yours is too. You can gain a ton of clearance if you dimple your pipes and pull them up a bit. I did and am pretty far off the ground.
I am not lowered, but at the lowest point, my true duals give me about 4.5" of ground clearance.
this is one of many pics on my site. There is a pretty good step by step of how I made the whole thing.
click this link for the full showing of pics and timeline.
1991 Chevrolet Camaro - Dennis's Chevrolet
hope this helps. Oh and please read the captions in the pics, they will answer 90% of the questions you might have.
They are hooker 2210's
Later
-Dennis
Old Sep 7, 2006 | 12:59 PM
ssean92's Avatar
Car: sold
Later
-Dennis
how do they fit around the t56???? i have a set that i am wanting to use
Old Sep 7, 2006 | 01:14 PM
Engine: LS3
Umm... Just fine. The only closr part is by the slave. I have heat wrapped the pipe and the slave since i took this pic. But here you can see the closest part. There is room all over the place exept there. Not a big problem.
I can get pics of the heat wrapped vertion if you want, but it is not any more insightful than these.
Old Sep 7, 2006 | 05:36 PM
ssean92's Avatar
Car: sold
thanks for the pic. i will be using them soon. thanks again
Old Sep 7, 2006 | 06:15 PM
Firebat's Avatar
I know someone is making a custom T56 crossmember or something for true duals. Can't remember who.
Old Sep 7, 2006 | 09:29 PM
thats fine for a T56 but I dont have that ...I have the 700r4..can it still be done? For some reason Im stuck on long tubes..1 3/4 that is..cause its suppose to sound better and give more power...and since im building a 383..I want all I cant get...
I remember a long time ago seeing some 3 or 4 inch oval pipe..is that stuff still around?
Old Sep 8, 2006 | 06:51 AM
likeenz24's Avatar
Car: 87 Camaro
Engine: 406
Axle/Gears: 9" ford 35 spline axles
Here ya go......- Skulte Performance Designs
Old Sep 8, 2006 | 06:54 AM
Engine: LS3
yes oval pipe is still around and doing well. There are more than a few companies now that make it. Google it.
As for using an auto, you have even less to worry about than the T-56 guys like myself. Autos are thinner, you have no slave poking out the side.
You will be fine shoving whatever auto you want in there.
Old Sep 8, 2006 | 10:45 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Autos have more clearance at the collectors because there's no slave cylinder, but are much larger everywhere else.
Old Sep 8, 2006 | 11:42 AM
Car: 89 Formula
Engine: 383 SBC/HSR
My exhaust pipes were cheap and they worked great. Hedman extensions, straight pipe, and proso spiral flow mufflers with turndowns($140 jegs). $70 was all it cost to have the ends cut and flared at a shop. A buddy welded the pipes together after we measured it all out, it worked out great.
Frozer!!!
Jan 19, 2024 04:55 PM
italiano67
Dec 11, 2016 09:21 AM
87iroctheo
Dec 4, 2016 11:47 AM
formula_novice
Sep 5, 2015 03:58 AM
beast94
Aug 20, 2015 06:44 AM
