Which headers with angle plugs?
Old Sep 27, 2006 | 07:04 PM
systalis's Avatar
Car: 92 RS
Engine: Built 355
Transmission: Built 700r4
Axle/Gears: 3.73's w/ stock axles
I have an engine about to go in my 92 RS with a set of GM 292 angle plug heads. Which headers would fit with these heads?
The car has sportline springs with bilstein shocks and struts so its lowered a little. I've been told that hooker supercomps will hang too low with a lowered car, and my searches here have informed me that headman makes a set of full length headers that will fit angle plug heads with more ground clearance. The only thing I don't like about the headmans is that they are 1 5/8" primaries and I would like 1 3/4".
I'm not against shorties if I could find a set that fit angle plug heads.
All help greatly appreciated.
Old Sep 27, 2006 | 08:15 PM
LilJayV10's Avatar
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
What size is your engine? 1 5/8 will support a lot of power. I have seen posts that larger engines made more power with the smaller 1 5/8 over 1 3/4.
Old Sep 27, 2006 | 08:36 PM
systalis's Avatar
Car: 92 RS
Engine: Built 355
Its a 350 bored .040 over. The guy building the engine says that it should make over 400 horses at the crank plus I'm planning on a 100 shot or so of N2O. I always thought that the increased flow of the 1 3/4" primaries allowed the engine breathe better, producing more power. I guess I stand corrected.
By the way, the car is not a daily driver....only about 25 miles a week.
Old Sep 27, 2006 | 09:20 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
i have headmann headers on mine and I do alright
Old Sep 29, 2006 | 01:40 PM
systalis's Avatar
Car: 92 RS
Engine: Built 355
Do any of you guys run hedman long tube headers with lowered cars?
1992 Trans Am
May 10, 2023 07:19 PM
evilstuie
Feb 28, 2016 03:33 PM
CRFred
Feb 7, 2016 11:39 PM
91REDZ28VERT
Fabrication
Sep 3, 2015 02:28 AM
tricky1
Aug 23, 2015 01:17 PM
