SLP headers, AFR heads, straight or L98 plugs?
Old Feb 4, 2007 | 04:52 PM
  #51
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
ok had a chance to take off the headers and try them out on my new heads, I'am going to start a new thread on it.
Old Oct 19, 2007 | 11:49 AM
  #52
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Re: SLP headers, AFR heads, straight or L98 plugs?
Originally Posted by LilJayV10
Yeah i think he got them mixed up.
Once and for all ....he was mixed up.
I straightened him out.
AFR makes two angles
(1)The L98 which will work with most headers.
(2)The AFR comp angle will not work with SLP headers.
they angle in "and" down unlike the L98 which only angles "in".
Old Oct 20, 2007 | 01:20 AM
  #53
LilJayV10's Avatar
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
Don thank you for the post. I was wanting to ask you about your headers anyway. Do you make 1 3/4 shorty headers w/o A.I.R. tubes? I like the fact that your y pipe is not bottle necked like the SLP's are. I have a set of SLP's that I was going to cut the flanges off and weld on 2.5 or 3 inch ball flange collectors like you use, then have a custom y pipe w/ the flowmaster mergy pipe into the 4in mufflex I have. Would a 2.5 y pipe be big enough or cause turbulence going into the 4 inch cat back?
I have a spohn tubular k member so that should help with room for the y pipe. I was wondering if it would be cheaper to buy a set of your headers y pipe.
I would go long tubes but the car will be lowered some, Eibach pro kit. I have had a set of hooker L/T and they hang pretty low. Thats why I am going to stick with the 1 3/4 shorties. If you have any ideas I would appreciate it.
Old Oct 20, 2007 | 01:43 AM
  #54
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Yes, I was confused and mixed up. Sorry everyone. I edited my posts for future reference.
L98 angle works, regular angle does not.
Old Oct 20, 2007 | 09:58 AM
  #55
Dyno Don's Avatar
Yes I have one set right now w/o air tubes.
I can make the 2 1/2" y-pipe exit into a 3 1/2" but that is the biggest I can do.
These will fit L98 angle heads and straight.
Send me a PM for more info.
Old Jun 27, 2022 | 02:00 PM
  #56
89Kicker_IROC-Z's Avatar
Car: 89' IROC-Z
Engine: HSR B2L 350ci w/LT4 hotcam and AFR 195's
Transmission: Transgo'd 700R w/Yank 2800
Axle/Gears: 9 Bolt, 3.45
Originally Posted by jaykar
Autolite 3926
HTH
Later
3926 is normal length, it is not a shorty. Compared to a 3923 the only difference is a slightly narrower collar on the 3926, just by a few hairs and it will not make any difference at all for clearance.
So either you got an older style plug which is no longer made or this info is wrong.
Cylinder #8: If you are running the L98 angle heads, the spark plug boot will touch on the SLP 1 3/4 style headers (UN-DENTED) and it WILL melt it eventually and cause arcing. Cylinder #3 is very close but its not as bad as #8.
Even running an Accel "Shorty" equivalent to an Autolite #3924 which is P/N:0416S with the AFR recommended reach of .750@14mm, the "shorty" is not very short at all. Maybe a 1/16 of an inch shorter than a regular Autolite or NGK, which is basically nothing.
You will need to run a heat-shield sock (which will touch and burn) and pray for the best. The best option for cylinder #8 when running SLP headers w/L98 angle AFR heads is to have the pipe cut/extended/welded then re-ceramic coated.
The plug that should be used for SBC AFR 195's is the Autolite #3924 or equivalent; that is if its a N/A motor with normal compression.
If you need the little teeny tiny bit of extra clearance on the headers, the Accel 0416S, can be used. The S is for "Shorty", but its not much shorter than the regular Accel 0416.
If you are running boost or a motor with 11:1+ compression, an Autolite #3923 is what AFR recommends for their SBC heads.
I know this thread is very old but after researching plugs and trying different ones for my SLP/AFR 195 combo, this info will be helpful for future viewers.
Tip: Do not run platinum plugs with a regular SBC street motor w/typical HEI ignition. Just use regular copper style electrode plugs.
Old Jun 27, 2022 | 06:47 PM
  #57
Camarothatcould's Avatar
Car: IROC/F250 7.3
Engine: LS12367
Transmission: Autos
Holy crap.
Howdy stranger
Old Jun 27, 2022 | 07:14 PM
  #58
Car: 89' IROC-Z
Originally Posted by Camarothatcould
Holy crap.
Howdy stranger
I'm still around, lol.
89Kicker_IROC-Z
Feb 21, 2005 10:22 PM
88 350 tpi formula
Feb 13, 2005 11:11 AM
'87FAKE-IROC-Z
Dec 20, 2001 04:59 PM
Joseph Andres
May 3, 2001 10:25 AM
