SLP & Mufflex 4" question?
Old Oct 16, 2006 | 09:36 AM
Randy92Z's Avatar
Car: 92 Z28 convertible
Engine: Miniram 383
Axle/Gears: 4.10 stk 10 bolt
I currently have the SLP 1 3/4 headers and was wondering if I could somehow get the 4" Mufflex pipes to better merge into the SLP Y-pipe connection without haveing too much restriction? Im thinking some exhaust shops could cutomize it for me. Anyone have something like this done?
Old Oct 16, 2006 | 02:53 PM
CraZ-28's Avatar
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
Yeah, your going to need to get a custom made y-pipe after the cat(s). I'm currently trying to do the same thing. Shouldnt' be to hard to get accomlised. Just look for a reputable shop that has decent welders and they should be able to whip one out for you in no time.
Old Oct 16, 2006 | 03:08 PM
Randy92Z's Avatar
Engine: Miniram 383
CATS?? I dont have any stinkin cats! LOL. What I had in mind was to pretty mutch keep the stock Y pipe in tact, but to cut off most of the opening at the end just after the two 2 1/2 pipes come together on the SLP Y-pipe. Then have a 4" pipe oval'ed just a bit at the end and welded onto the stock SLP Y-pipe. So it basicly becomes a two 2 1/2 pipes into a 4" outlet. But I think you know what Im talking about anyways. LOL.
Old Oct 16, 2006 | 06:16 PM
Jetmeck's Avatar
Car: '89 GTA 9,000 MILES
Axle/Gears: 3.27 9 bolt
Sounds like a damn good plan. I have always thought the 3 inch cat would have to be a restriction in front of the 4 inch Mufflex pipe. I don't know of any 4 inch cats out there. While I don't have sniffer tests in my area I have had guys take a look under one of my birds with headers, gutted cat and a flowmaster exhaust looking for a cat while inspecting it. I am sure if they hadn't saw a cat there
it would have failed , even though they don't know it is gutted.
Old Oct 18, 2006 | 01:23 PM
CraZ-28's Avatar
Car: 1991 Z-28
Well, I don't either but I need them for a visual. Thats why I have 2 straight pipes covered by the shells of my old cats. Looks pretty trick.
Old Oct 18, 2006 | 02:37 PM
Jetmeck's Avatar
Did you cut them on the top side and pipe them or what ?
Have been considering this ?
Old Oct 18, 2006 | 06:31 PM
Randy92Z's Avatar
Engine: Miniram 383
I havent done anything yet, Im just looking for better exhaust options for my 500 hp 383 Ill have when I come home from iraq.
Old Oct 18, 2006 | 07:44 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
they make 4" cats but I never looked at any small case ones for cars. I would bet they make those too though
Old Oct 19, 2006 | 05:11 PM
CraZ-28's Avatar
Car: 1991 Z-28
Na, what you do is you cut the cat off and look for where they weld the shell to the pipe. When a cat is contructed, only about 1/4 to 1/2 inch of the pipes on each side are welded to the shell. So you make the cut right there and the pipes come right out. I then gutted mine, took 2 pipes that were 2.5 inches and stuffed them through the shells. Then welded the shells back to the pipes. Looks just like it did when I bought them....minus a few inside peices.
fonzie85
Exterior Parts for Sale
39
Mar 16, 2016 07:07 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
Thirdgen89GTA
Aug 20, 2015 12:11 PM
redmaroz
Aug 16, 2015 11:40 PM
