Percy Deadsoft Alum Header Gasket?
Old Oct 22, 2006 | 08:31 PM
AC's Avatar
AC
Car: Used to drive a camaro
I was always told the only dumb question is the one not asked, SO. Which direction do you install Percy's deadsoft alum headers gaskets? I mean when you look at the gasket there are two pieces that are spot welded together. One face is planer and the other side has a raised parameter. ??? I'd just rather ask then install and find out later I f***ed up.
Old Oct 22, 2006 | 08:44 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
i always put the raised portion pointing towards the headers, but i don't think there is a wrong way to install them
Old Oct 22, 2006 | 10:26 PM
Wishmaster's87IROC's Avatar
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
dont think they wont leak..cause they will, I blew out 2 sets on my old 305 attached with SLP tri-y's
Old Oct 23, 2006 | 12:45 AM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
I'll second that.
They almost seem worse for seal than regular gaskets to me.
Never had luck with them and have done quite a few header installs in my lifetime.
later
Jeremy
Old Oct 24, 2006 | 06:39 PM
yep..they are a waste of $30 plus dollars!
Old Oct 24, 2006 | 07:55 PM
AC's Avatar
AC
3.8 & Wish, you think there that bad huh? What do you suggest? I'm running Dart Iron heads and 2210 headers.
Old Oct 25, 2006 | 07:11 AM
B Rhodes's Avatar
Car: 91 B4C
Ive had better luck with the solid copper gaskets than percey's aluminum ones on headers. But I do have their aluminum collector gaskets on some longtubes in a 67 pick up that have been leakfree for a couple years.
Old Oct 29, 2006 | 08:23 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
The Percy gaskets I have havent leaked in 5 years on the truck or 2 on the bird. I did have one rip apart on the truck but when you drop a u joint at 80 and all the bolts vibrate out it's not the gaskets fault.
Old Oct 29, 2006 | 08:43 PM
Justin89Formy's Avatar
Car: 89 formula 350
Engine: ls1 magnuson tvs2300 supercharger
Axle/Gears: 4.11 Dana 44!
they key to leak free header gaskets are stage 8 locking header bolts
Old Oct 30, 2006 | 03:37 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
hey ac i forgot the exact model of mine, but they have those replacable inserts inside the gaskets, i havent had any problems with mine.
z 28 jari
Sep 14, 2021 10:03 PM
Chad Speier
Sep 24, 2015 12:32 PM
bamaboy0323
Sep 12, 2015 07:14 PM
hdis2002
Sep 8, 2015 02:52 PM
dmtz956
LSX and LTX Parts
Sep 7, 2015 10:16 PM
