Put exhaust on the $1,200 ******
Old Oct 23, 2006 | 06:22 PM
fast86z28's Avatar
Car: 91 Z28
Engine: LB9
Transmission: WC T5
Had them shoot it out the side, it exits right before the rear tire. I'm really happy with the way it turned out. Sounds good, but now I can hear the header gaskets are leaking lol.
Old Oct 23, 2006 | 06:53 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
that's how mine is run now, although you can't see my pipes from the side at all
Old Oct 24, 2006 | 07:06 AM
BulliTooth's Avatar
Car: 1989 Formula
Axle/Gears: 9 bolt GW6
gotta pic from under the car? u running longtubes?
Old Oct 24, 2006 | 03:09 PM
Demon355's Avatar
Looks good, need more pictures though!
Old Oct 24, 2006 | 03:20 PM
jkicak's Avatar
Car: 87 Formula 350
the only thing i don't like about it is that it's only on one side...
Old Oct 24, 2006 | 03:25 PM
fast86z28's Avatar
Car: 91 Z28
Engine: LB9
Transmission: WC T5
Its not true duals.
Old Oct 24, 2006 | 03:39 PM
Stevo's Avatar
Car: Pair of 92 Z28s
I like it, i was thinking of that but where did you put the muffler? If you have one of course.
Old Oct 24, 2006 | 03:43 PM
fast86z28's Avatar
Car: 91 Z28
Engine: LB9
Transmission: WC T5
The cat runs right beside the rocker panel off the y pipe, the it goes on the other side of the subframe connector, the muffler runs next to the sub frame connector, then it goes back into a rounded turn and straight out the side.
Hopefully that makes sense.
Old Oct 24, 2006 | 05:04 PM
Stevo's Avatar
pictures?
Makes sense but id like to see it. It does look great though!
1992 Trans Am
May 10, 2023 07:19 PM
TheExaminer
Aug 26, 2015 04:59 PM
86IROC112
Aug 17, 2015 02:00 PM
