what is this???
Old Nov 5, 2006 | 09:37 AM
impaled's Avatar
Car: 1985 Camaro and 1996 Mustang GT
Engine: 350 4bbl/281
Transmission: 700R4/4R70W
Axle/Gears: 9" rear/8.8" 4.10
what is this???
i just bought my first camaro and i noticed that it has an exhaust leak. i am checking it out, and i think it is coming from the right side where the header joins the y-pipe. under there, i see this thing coming off near the joint which looks like something that a vacuum line would attach to (but there is no vacuum line attached.) i have no idea what it is and would appreciate if anyone could tell me what it was, i briefly checked the haynes and found no quick answer. i may also note that this thing, whatever it may be, is not on the other side by the other header.
if it is of any importiance, it is a 1987 Camaro with the 305.
thanks.
Old Nov 5, 2006 | 09:44 AM
black355formula's Avatar
Car: black 88 formula
Engine: 355 tpi
it sounds like the air pipe but i dont know
Old Nov 5, 2006 | 09:48 AM
Justin89Formy's Avatar
Car: 89 formula 350
Engine: ls1 magnuson tvs2300 supercharger
Axle/Gears: 4.11 Dana 44!
yeah it sounds like the metal line that is supposed to run from the catalytic converter to the AIR system on the manifolds?
Old Nov 5, 2006 | 07:09 PM
HiPerf_Chevyman's Avatar
Car: 1991 Camaro RS
Engine: The Wicked six'ah
Axle/Gears: stock 3.08's
Its Sounds the AIR Tube.... Which Matches all his descriptions.. Exhaust leak.. Ect..
Old Nov 5, 2006 | 07:42 PM
chevylover5's Avatar
Car: 1992 Camaro vert
Engine: 355
Axle/Gears: 10 bolt... not blow up yet
YUP i was gonna say tha same thing. id say its prolly a 95% chance that that is what it is. ur prolly missing the line or it just fell off from vibrations.
Old Nov 5, 2006 | 07:58 PM
impaled's Avatar
FYI, i just bought this car last week and am now just initially starting to play with it. and trying to figure it out, so im still not too sure.
is it importiant to have it hooked up?
could this be why i have an exhaust leak?
Old Nov 5, 2006 | 08:17 PM
Car: 1991 Camaro RS
100% Exhaust leak.... Important for Emission laws... but I'd plug it for now..
Old Nov 8, 2006 | 01:45 PM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
Are you sure its not the ehaust manifold heat riser.
