header bolt / need help
Old Nov 16, 2006 | 08:28 PM
xgtharo86x's Avatar
Car: 86' Trans am
Engine: 85 LG4-non cc carb(building a 350)
Transmission: Rebuilt 700R4,vette servo,2200stall
Axle/Gears: 2.73 Posi
i put hedman headers on my car and the passanger side keeps loosening and blowing out my gasket, is there a trick too keep the bolt tight....i have circle aftermarket gaskets if the stock gaskets are round can i use them instead would that be better?
Old Nov 16, 2006 | 09:45 PM
crowebuilt's Avatar
try a set of percys. i have used them on several engines with headers, and have had great results. another that i want to try is Mr gasket solid copper they have an embossment to help seal.
Old Nov 17, 2006 | 07:23 PM
camarodarrell's Avatar
Use lockwashers on the header bolts. Did the trick with mine after the header bolts kept loosening up. I use felpro gaskets and they have loosened up many many times but never blew the gasket out. Or summit sells locking header bolts but they are about $40 plus their handling charge of $10 or so.
Old Nov 17, 2006 | 07:58 PM
iceman02's Avatar
Car: 91Z28 L98
Engine: HSR 350
Transmission: Goebel 700R4
You've got two realistic options. One is the Stage 8 locking header bolts that are about $40 mentioned above. HERE Available throught Summit Racing. Another option is the Breslin locking header bolts. HERE Also carried by Summit. I have never had a stage 8 locking header bolt come loose. Right now I'm running the Breslins, but 3 or 4 have fallen out. I don't blame the bolts, but the fact that my exhaust is hanging by the headers.....
click the 'HERE' for links
Old Nov 18, 2006 | 06:56 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
I didn't want to cough up that kind of cash on bolts.
Just re-tighten them after they heat cycle, and they should hold after that.
You can also use lockwire, but once you pay for the parts to lockwire your stuff, and then go through the immense hassle, you'll wish you just bought the stage 8's.
Old Nov 18, 2006 | 08:32 PM
That didn't work for me, they would still loosen back up. Maybe it's because my headers are stainless though. When stainless heat cycles, it expands and contracts more than mild steel. Just put some lockwashers on there. Cheap and it works.
Old Nov 18, 2006 | 08:55 PM
Sonix's Avatar
Car: 1982 Trans-Am
hmm, I was about to argue with your darrell, I thought the thermal coefficient of expansion for SS was smaller than MS. But I was wrong, ~8 vs ~18x10^-6. The thermal conductivity is much lower in SS than MS, that's what I was thinking...
well heck, use SS bolts then
Old Nov 18, 2006 | 09:36 PM
Justin89Formy's Avatar
Car: 89 formula 350
Engine: ls1 magnuson tvs2300 supercharger
Axle/Gears: 4.11 Dana 44!
percys dead soft aluminum gaskets, and stage 8 locking bolts. havent had a loose bolt or a leaking header gasket in 3 years!
Old Nov 18, 2006 | 09:49 PM
That's a good idea!
Damn! I bet! Sounds bulletproof for no leaks. I am definately going with that setup when I drop my new motor in. No more annoying ticks.
Last edited by camarodarrell; Nov 18, 2006 at 09:51 PM. Reason: Automerged Doublepost
tom1985
Apr 19, 2016 07:55 AM
LT1Formula
20
Nov 14, 2015 12:02 AM
hectre13
Sep 8, 2015 03:38 PM
theurge
Aug 21, 2015 12:46 PM
Dialed_In
Aug 20, 2015 01:45 PM
