Cat & AIR & Hedders question...
Old Feb 8, 2007 | 02:12 PM
luvofjah's Avatar
Car: 91 Black Formula KR
Engine: 305 TPI R69/G92
I recently had my Hooker 2055's put into my 91 305 TPI.
I know the AIR tubes on the headers were connected to the valve body stuff in the engine compartment...
My question... the tube that goes to the cat...
Where does it connect?
I'm not sure if my old one was thrown away, can I still order one of these, have one made, not worry about it??? Just need some options...
I want to get this figured out and ready before I take the car to the muffler shop to weld in new SFC's and 3" exhuast...
Thanks,
Rafael
Old Feb 8, 2007 | 04:28 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The A.I.R. tube to the cat starts at the diverter valve.
Old Feb 8, 2007 | 04:38 PM
luvofjah's Avatar
I will look and see what I have...
A replacement, GM or Hawks or can this be fabbed up?
Raf
Old Feb 8, 2007 | 04:50 PM
five7kid's Avatar
GM, replacement, or used. I can't imagine it being fab'd up.
Based on price, I'd go for used.
Old Feb 9, 2007 | 11:48 AM
luvofjah's Avatar
Found a new one from the parts store AC Delco I think with 1 year warranty
$28!
For anyone else reading this...
Old Feb 11, 2007 | 08:52 PM
luvofjah's Avatar
Another question for those who know...
I went and ordered the AIR pipe to cat... I saw on the receipt when I got home that it says engine code E, my vin has an F, it's a tpi, I assume the E is the TBI... should it still fit, I hope the parts are all located in the same places for TBI and TPI...
Raf
Old Feb 25, 2007 | 07:32 PM
pearl_iroc's Avatar
Car: 1988 Iroc-Z 28 Camaro
Engine: LSX
Transmission: MN12
hey luvofjah im lookin into gettin headers and i came across ur post i noticed that the type of headers u are using do not come with air tubes, so u are installing ur old air tubes from ur original exhaust manifold? if so is it an easy install that my muffler shop should have no prob with?
Old Feb 25, 2007 | 08:01 PM
luvofjah's Avatar
You can get the headers with / without air tubes...
I still have the stock 305 TPI, so for now, I wanted to keep the AIR stuff...
Maybe later it can get chopped off...
But if you bought your headers without, it would be quite expensive to get back on... a lot of welding...
Raf
Old Feb 25, 2007 | 11:32 PM
pearl_iroc's Avatar
Engine: LSX
Transmission: MN12
ok cool, so ill definetly have to get headers with air tubes then as i still need to pass emissions , thanks
Old Feb 26, 2007 | 09:49 AM
abyliks's Avatar
Car: 02 Mustang
Engine: 3.8 about to be punched out to 4.3
Transmission: 4R70W
Axle/Gears: 3.73 Detroit true trac
what would happen if you just disconected the AIR tube from just the cat? would it idle weird or cause a SES?
Old Mar 6, 2007 | 09:33 PM
luvofjah's Avatar
Ok, need more help...
The cat to diverter pipe was from GP Sorenson, not AC Delco and it was for the TBI, not TPI engine...
So now I'm looking for a new one, GM or anyone else... can someone point me in the right direction, it's the last piece I need before going to the muffler shop to have the Spohn SFC's and exhaust welded in...
Rafael
Old Mar 6, 2007 | 11:32 PM
five7kid's Avatar
I was wondering how you found one so cheap. I looked on www.partsamerica.com for your application, don't recall now exactly what it said, but well over $100 seems right. That's why I suggested used.
A bunch of people on this Board take off A.I.R. I'd think a post in the parts wanted classifieds should yield some results.
Old Mar 12, 2007 | 02:16 PM
luvofjah's Avatar
I found the proper one (hopefully) at www.rockauto.com for $17, about $27 shipped.
I should have it tomorrow, we'll see
this is a great place to get hard to find stock parts, you can see pics, etc..
I will probably remove the AIR stuff once I rebuild / replace, but the motor is still plenty strong and fun for now.
Rafael
Hotrodboba400
Dec 10, 2019 07:07 PM
db057
Apr 28, 2019 07:45 AM
83 Crossfire TA
Jan 3, 2016 01:26 PM
Stryker412
Sep 7, 2015 09:11 AM
