hedman headers hitting coolant line
Old Mar 4, 2007 | 11:52 AM
fin170703's Avatar
Car: '87 iroc camaro
Engine: 350 L98
Transmission: 700-R4
Axle/Gears: 3.27 posi
Looking for solutions ??
The pipe has a small bit of play but not enough to get it out the way . i though about wedging a bit of heat dispersing material between the pipe and primary ??
Took the car out for a test drive and it overheated . Its probably not just the coolant line but it certainly wouldn't have helped
Old Mar 4, 2007 | 12:30 PM
tsibouky's Avatar
Car: 85 black on red t-top t/a
Engine: 305 h.o. l69
Transmission: t-5
Axle/Gears: borg w/ discs 3.70 posi
the same thing happend on my tbi, the pipe was rusted and broke when installed my hedman sorties, that pipe goes from the rad or t-valve to the firewall for ur heater core, all u have to do is bypass the pipe get a hose from an auto parts store and reroute the line, its very simple just use ur head and u will easely figure it out
Old Mar 7, 2007 | 01:39 PM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
I diplled my header to clear it.
Old Mar 7, 2007 | 03:55 PM
bilms01's Avatar
Car: 89 Firebird
Engine: 350 Ramjet
Axle/Gears: GM 9 bolt 3:27
I have the same problem with mine also. As soon as I put my AC delete box in. I was going to try and fab a copper tube to replace the original coolant line.
I think it should work.
italiano67
Dec 11, 2016 09:21 AM
hectre13
Sep 8, 2015 03:38 PM
theurge
Aug 21, 2015 12:46 PM
Dialed_In
Aug 20, 2015 01:45 PM
