Does muffler placement affect performance?
Old Mar 14, 2007 | 04:45 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
I'm building my own exhause and am wondering if muffler placement affacts performance? For example, will having the muffler where the cat was located and an exit at the rear of the car as normal perform differently than the same muffler places past the rear axle?
Old Mar 14, 2007 | 06:34 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
No effect. With long tube headers, you can get a "torque tube" effect by having the mufflers no closer than what the length of a torque tube would be for your engine (good reason not to use header mufflers). With shorties or stock manifolds, you're long past that with a muffler in the cat location. No difference either having "straight" pipe from the cat inlet location back to the stock muffler location.
Old Mar 15, 2007 | 03:24 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Thanks for the reply. I'm still undecided whether to go for a single in/out in the location of the cat splitting to 2 exits once past the axle or a cross flow muffler after the axle.
Old Mar 15, 2007 | 03:33 PM
five7kid's Avatar
I've about talked myself in to taking off the crossflow and putting a single in/single out in its place. I haven't seen any "real" numbers, but the word is crossflows hurt flow.
PurelyPMD
May 5, 2016 04:57 PM
88SS6SPEED
Nov 11, 2015 07:05 AM
Tarizza
Sep 24, 2015 12:57 PM
cstrobel65
Sep 16, 2015 11:54 AM
Stroopwafel
Sep 11, 2015 06:38 AM
