exhaust shops around phoenix
Car: 91 rs
Engine: 305tbi
Axle/Gears: 3.27 9bolt
anyone know of a shop around phoenix that could fabicate a dual 2.5" exhaust for my camaro. its a 91 rs with an auto trans. either i find someone to fabricate me one or i do a 3" single with dual outlet. does anyone make a 3" inlet/outlet y pipe?
Transmission: 4L80E/4L80E
Still a 305 TBI?
Headers? Stock manifolds?
A shop legally couldn't make dual exhaust until after the cat.
If you get Hooker 2055 headers they include a y-pipe that is 2.5" from each side merging into a 3" pipe at the cat. Mandrel bent, never smaller than 2.5" from each side or 3" once they join together.
Car: 91 rs
Engine: 305tbi
five7kid
so the y -pipe would hook up to a 3"inlet/outlet high flow cat? then i get a 3" cat back(lets say flowmaster american thunder) and That'll cover the whole exhaust? how much gain should i see from this? need any reducers/other hardware? will it all work with stock hangers? i know this isn't exhaust related but do you reccomend a drop or non drop base open element to work better with a full exhaust? thanks much. will i be able to pass emissions? do the 2055's come with all the emissions hook ups? all of this should bolt up correct? don't have access to welder
If you're looking for a shop in NW Phoenix, try Pro Muffler in Glendale. It's located on the SW corner of the 101 and Bell Road behind the car dealerships. They did excellent work on the exhaust on both my 90 IROC and my 92 RS.
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
