Question regarding header bolts
Old Mar 15, 2007 | 03:30 PM
chevypower91's Avatar
Car: 1991 Camaro Z28
Engine: 305 cid
Transmission: 5 speed
Axle/Gears: Posi/3:42
I just removed those annoying bolts as I need to replace the header gasket on driver's side, but I wanted to know if I should replace the bolts with the bolts that require the allan key. Have any of you ever used these bolts and if so, did you find it easy to access them and tigthen them?
Thanks,
Benny
Old Mar 15, 2007 | 03:39 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
You could use bolts with an allen socket head. I like the Stage 8 locking bolts, they have both a hex head and an allen socket.
Old Mar 15, 2007 | 03:47 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I'll say this about my Allen head header bolts - I'm sure glad they were hex head, too!!!
Old Mar 15, 2007 | 03:49 PM
1BADRZ28's Avatar
Car: 1982 Camaro
Engine: 555 BBC
Transmission: TSI Glide
Axle/Gears: Aluminum Moser 3.89
I have had every big tube header on the market for a 3rd gen. The 3/8 head bolts work fine. But if you want to be different those should work fine.
Old Mar 15, 2007 | 04:03 PM
Engine: 305 cid
Hi Apeiron,
Thanks for the reply. Do you have a pic of this stage 8 locking bolt that you can post?
Thanks again.
Old Mar 15, 2007 | 04:11 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
http://www.stage8.com/
Old Mar 16, 2007 | 12:16 AM
Comp788's Avatar
Car: 1982 Z28 & 1967 RR/SS 396
Engine: ZZ383 & 375hp 396
Transmission: T56 & factory TH400
Axle/Gears: 9" ford & 12 bolt 4.10
I always use either 5/16" or 3/8" header bolts. With those small heads it makes it easy to get a wrench on them.
Frozer!!!
Jan 19, 2024 04:55 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
redmaroz
Aug 16, 2015 11:40 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
