1 chamber flow master????
Old Apr 16, 2007 | 04:22 AM
ws6gta89's Avatar
Car: 1989 TRANS AM GTA
Engine: 355 L98
Transmission: Built 700r4
Axle/Gears: BW 3.27
Would a single 3 inch 1 chamber be raspy like a bullet or deeper like a 40 series???
Old Apr 16, 2007 | 10:11 AM
my3rdgen's Avatar
Car: 2013 Challenger RT
Engine: 5.7
Transmission: 6 spd
Axle/Gears: 3:92
Re: 1 chamber flow master????
Are you talking about the flowmaster system with the single 3 inch outlet or the flowmaster system with dual 2.5 outs? I am not sure which system you are refering to.
I am using the American Thunder system with the dual 2.5 inch outlets. It has a very loud very deep rumble to it (with a cam anyway).
Old Apr 16, 2007 | 02:56 PM
ws6gta89's Avatar
Engine: 355 L98
Axle/Gears: BW 3.27
No no a catback i have already had that i was talking about the 1 chamber race muffler i was going to put it were the cats used to be and run pipes out the back like stock im done with having dumps and i want something a little louder than my aero chamber but not as rasy as the bullets i used to have
Old Apr 16, 2007 | 03:13 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
actually the 1 chamber gives less of a drone than the original 40 series, but more higher rpm sound..i like it..i have one on my dodge charger, i took of the 40's they had more vibration too..
Old Apr 17, 2007 | 03:24 AM
ws6gta89's Avatar
Engine: 355 L98
Axle/Gears: BW 3.27
do you mean louder at high rpm's but the same at low rpm"S
Old Apr 17, 2007 | 02:20 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
actually they are less annoying at lower rpms. close to same sound but way less drone, because the 1 chamber's use 3 baffles and 1 chamber. and the 2chamber has exactly that but 1 baffle
Old Apr 17, 2007 | 03:32 PM
ws6gta89's Avatar
Engine: 355 L98
Axle/Gears: BW 3.27
So the 1 chamber is louder but has less drone and more flow?if that is true then why wouldnt more people use them?
Old Apr 18, 2007 | 04:56 PM
Rob Wade's Avatar
Car: 89 jaguar xjs convertable
Engine: 89 L98 5.7 TPI
Axle/Gears: 3.23 dana 44
I had a pair of them on my BBC in 3 1/2". 10 1/4:1 with 610 lift and and lots of duration. Sounded VERY nice. Your sound may vary depending on where you mount them. I ran mine about 24" behind the headers and out in front of the rear tires.
Old Apr 19, 2007 | 02:26 AM
ws6gta89's Avatar
Engine: 355 L98
Axle/Gears: BW 3.27
does anybody have a sound clip of one on a third gen?
Old Apr 19, 2007 | 09:52 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
i dont think anyone really knows about as much.flowmaster doesnt relaly push them if u look into summit they have a tiny lil article about them
Old Apr 19, 2007 | 11:03 PM
deepstage69's Avatar
Car: '92 RS, '84 Z28
Engine: 383, L69
Transmission: T56, 700R4
Axle/Gears: 3.42, 3.42
http://videos.streetfire.net/video/b...cf017fddad.htm
I made that a few years back, wasnt that loud just deep. this was a monsterous 305 TBI and by monsterous I mean stock.
Old Apr 20, 2007 | 03:28 AM
ws6gta89's Avatar
Engine: 355 L98
Axle/Gears: BW 3.27
how could a muffler that small and dumped not be "that loud"?
Old Apr 20, 2007 | 10:56 AM
Engine: 383, L69
Dont get me wrong it was louder than the 80 series what was on there, but it wasnt as loud as i thought it would be. But at the same time, it would be louder if there were more cubic inches in front of the muffler.
Old Apr 20, 2007 | 11:37 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
good muffler im tryin dynomax out now
Old Apr 21, 2007 | 12:39 AM
Screamin86's Avatar
Car: 86 Trans Am,03 Yukon,92 Z28
Engine: 5.3, 5.3, lb9
Transmission: th350,4l60e,700r4
Axle/Gears: 3.73,3.73,2.73
ill try and get a clip in the next month or so ill be running hedman longtubes into 2 1/2 true duals with flowmaster 10 series dumped should sound nice
Old Apr 21, 2007 | 02:49 AM
ws6gta89's Avatar
Engine: 355 L98
Axle/Gears: BW 3.27
Are you going to use a h-pipe or x-pipe?
Old Apr 21, 2007 | 11:56 PM
Screamin86's Avatar
probably an H pipe but at first ill have neither right now ive got the longtubes and the hedman extensions into the flowmasters it should stop right under the seats im only doing that because of money and im just tryong to get it goin again i still need another tranny for it. all money is tied up in the motor and tranny the rest of the exhaust will have to wait unfortunately but idunno i may go ahead and order the H pipe so we will see
Old Apr 22, 2007 | 03:24 AM
ws6gta89's Avatar
Engine: 355 L98
Axle/Gears: BW 3.27
Do you have access to a welder?if so just make your own h-pipe and save some money
Old Apr 22, 2007 | 10:41 AM
Screamin86's Avatar
no i dont but i may still just make one i have a few friends that have welders i also dont have the best place to work on the car as it is. ill probably just bolt on the extensions and the muflers and break in the cam and all the tuning and a few test runs to seat the rings and when im ready to actually take it out and drive it ill proba;y run it ove to my friends and finish up the exhaust with the H pipe and finish welding up all the pipes. i might not weld the mufflers on probably just clamp so if i wanna swap out mufflers i can
Old Apr 25, 2007 | 03:02 AM
ws6gta89's Avatar
Engine: 355 L98
Axle/Gears: BW 3.27
Im really lucky my dad has a shop that does everything so i have him weld everything for me until i get better at it without him i could never play with these cars....**** cost to much
Old May 3, 2007 | 02:30 AM
ws6gta89's Avatar
Engine: 355 L98
Axle/Gears: BW 3.27
screamin86 any progress?
Old May 12, 2007 | 04:17 AM
ws6gta89's Avatar
Engine: 355 L98
Axle/Gears: BW 3.27
anything yet?
Old May 12, 2007 | 12:26 PM
Screamin86's Avatar
lol loud!!!
ill try and get a sound/video clip tonight of it but i got it running thursdaynight and my god is it loud my buddy that lives at the end of my street about 10 houses down could hear it idleing
Old May 13, 2007 | 11:51 AM
Screamin86's Avatar
here is a clip right now im only running the headers extentions and mufflers are about where tranny xmember is enjoy. video takes away a lil of the sound but you get the idea. when i get some other things finished up with it ill make more videos http://www.youtube.com/watch?v=Idraf8vCbmA
Old May 14, 2007 | 03:57 AM
ws6gta89's Avatar
Engine: 355 L98
Axle/Gears: BW 3.27
WOW....thats to loud for every day driving i got tired of that from my old bullet setup but im sure it would sound good if i put the muffler were the cats go then run it out the back with the tips off my hooker catback,what all do you have done to the motor and what size cam do you have?and thanks for the clips
Old May 14, 2007 | 04:06 PM
RocsRose86's Avatar
Car: 1986 Irocz28/04 GMC Yukon
Engine: Ram Jet 350(*TPI*)
Transmission: Turbo 400 w/1500 stall
i have heddman headers and borla catback exhaust system with duals on one side with muffler and open on the other side with duals .
Old May 14, 2007 | 06:33 PM
Screamin86's Avatar
specs are in sig but like i said ima still add a h or x pipe and dump mufflers at axle that should give it a more toned sound but yea its loud neighbors werent happy when i got it goin.
Old May 15, 2007 | 04:03 AM
ws6gta89's Avatar
Engine: 355 L98
Axle/Gears: BW 3.27
keep me posted on your progress and some new clips when you finish it
Old May 15, 2007 | 08:18 PM
Screamin86's Avatar
i plan to get her on the road soon my new job ids gona help me alot w that. i still got some tuning issues but i ran it a lil today and it sounds good
Pac J
May 17, 2020 10:44 AM
Fireslash
Apr 11, 2016 06:43 PM
jaridjohn
Oct 5, 2015 07:01 AM
meeklay812
Oct 1, 2015 03:46 PM
usafirebird
Sep 29, 2015 11:58 PM
