flowmasters are they worth installing
Old Apr 22, 2007 | 05:45 PM
mightymouse383's Avatar
Car: 91 camaro
Engine: 383
Transmission: th350
Axle/Gears: 4:10
Have a 91 rs with built 383 and want to run true duals and dump them before rear axle, I like the way flowmasters sound but do they really perform?
Was checking out moroso spiral flow and dynomax bullets. Which would be my best bang for the buck and which would sound the best/perform? Any suggestions would help........thanks Nick.
Old Apr 22, 2007 | 06:21 PM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
Re: flowmasters are they worth installing
If you want maximum performance, you want a straight through design like the bullets. Flowmaster does offer one chamered mufflers though.
Old Apr 22, 2007 | 06:55 PM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Straight through mufflers is the best for performance...although you may find the noise unbearable. I would recomment the Flowmasters. They sound great when you put your foot down.............
Last edited by The Project; Apr 22, 2007 at 06:56 PM. Reason: Automerged Doublepost
Old Apr 23, 2007 | 04:18 PM
Car: 91 camaro
Engine: 383
Transmission: th350
Axle/Gears: 4:10
I kind of do want it to be loud and sound badass, the only thing i am worried about is if i install bullets with packing, I don't want a raspy sound like that peice of crapp SLP loadmouth that everybody is running, it reminds me of a honda fart tube!!! Just want something that sounds loud and aggressive.
Old Apr 23, 2007 | 04:54 PM
1989formula355's Avatar
Car: 89 formula, 89 Cadillac Brougham
Engine: 355,HSR,patriot alum. heads,TFS cam
Transmission: 700r4, 2500 B&M stall, shift kit
Axle/Gears: 3.73 ten bolt, powertrax locker
cherry bombs have come a long way.http://www.cherrybomb.com/products-front.asp
Old Apr 23, 2007 | 06:13 PM
Justin89Formy's Avatar
Car: 89 formula 350
Engine: ls1 magnuson tvs2300 supercharger
Axle/Gears: 4.11 Dana 44!
just say :no: to cherry bombs
Old Apr 23, 2007 | 07:30 PM
CobraBytez's Avatar
Car: 1983 Camaro Z28
Engine: 350 V8
I'm interested in the glasspack style too, my neighbor has them on his Mercury accross the street, and his 305 is a MILLION times nicer sounding than my 350...Who makes good ones?
Old Apr 23, 2007 | 07:47 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Asking what brand is better is really a loaded question around here... borderline dangerous actually.
I prefer Hooker myself... its built beefy, so it holds up well, and it also doesn't make it sound 'cheap' like alot of system out there. Has a nice growl under normal driving conditions, sounds REALLY gnarly at WOT, and just has a nice rumble at idle.
I have the '83-85 HO Hooker system on my Z28, and it made no difference at the track between through the pipes, or with the cutout open. None at all.
My cousin also runs a pair of Hooker mufflers (2x 2.5" in and out) on his 425hp 390ci Ford big block, and it makes no difference if he runs open headers or through the pipes.
IMO, Hookers are the best mufflers out there.
Old Apr 24, 2007 | 09:17 AM
89formula350b2l's Avatar
Car: 92 Camaro
Engine: Dart SHP 406 HSR, LE heads
Transmission: Performabuilt Level 2, Vig 3200
Axle/Gears: S60 373
I want to go hooker but i havent heard them...in person i mean. problem is i dont to get pulled over if they sound that mean but i dont want flowmaster b/c everybody and their brother has them. also hooker doesnt make a system for dual cats ive heard from many people they sound awesome though...
Old Apr 24, 2007 | 02:22 PM
8T9 BANDIT's Avatar
Car: 1989 T/A
Engine: PROCHARGED LB9
Transmission: FB BUILT 700r4 2200 stall
Axle/Gears: 10 BOLT EATON 3:73 POSI
305 in a mercury?
Old Apr 24, 2007 | 03:49 PM
CobraBytez's Avatar
Engine: 350 V8
305 in a mercury?
Yeah thats what I said too when he told me lol...It apparently came from an 80s Cutlass or something to that effect...Totally blew me out of the water!
Old Apr 24, 2007 | 04:02 PM
abyliks's Avatar
Car: 02 Mustang
Engine: 3.8 about to be punched out to 4.3
Transmission: 4R70W
Axle/Gears: 3.73 Detroit true trac
force pro series mufflers from jegs, exactly the same as flowmasters but fully aluminzed 16 gu and, for the big price of $35 have one on my car
Old Apr 24, 2007 | 04:22 PM
Car: 91 camaro
Engine: 383
Transmission: th350
Axle/Gears: 4:10
Yea ive seen those in jeggs,do they sound good? If so I might think about getting some of them.You can't beat that price.
Old Apr 24, 2007 | 07:33 PM
abyliks's Avatar
Car: 02 Mustang
Transmission: 4R70W
they sound pretty good heres my stock 305 with em
http://vids.myspace.com/index.cfm?fu...oid=2012117019
flowmaster
http://vids.myspace.com/index.cfm?fu...eoid=818712656
Old Apr 26, 2007 | 01:23 PM
Car: 91 camaro
Engine: 383
Transmission: th350
Axle/Gears: 4:10
When i get exhaust should run it to the rear axle and dump it or should i run it all the way to the rear of the car? It will be true duals.
Old Apr 30, 2007 | 09:01 AM
Camaro355Z28's Avatar
Car: '86 Z28
Engine: 355
Transmission: 5 speed
Axle/Gears: standard 3.23
kinda tells you something about them then doesnt it?? not only do they have that "you dont wanna mess with me" sound, but they have a sweet looking design and are built very strong. I have two 40 series mufflers that hang low and I have hit the curb at the end of my driveway several times and they have never gotten a dent or anything on them. by far the best mufflers around in my opinion...
Old Apr 30, 2007 | 09:17 AM
abyliks's Avatar
Car: 02 Mustang
Transmission: 4R70W
everybody i know has flows pretty much
my friends f150 has em and they lasted 8 months before they rusted out
another friends jeep had on that hung a little to low that got smashed on a rock
flows are not aluminzed, and, they arent really the strongest either depending on case, ive actually RAN my force muffer over and my buddy behind me ran it over as well and its still sittikng on my car $35>$80
a majoirity of the world also think that TB spacers and tornados are good for horsepower and gas milage
Old Apr 30, 2007 | 01:58 PM
Car: '86 Z28
Engine: 355
Flowmasters ARE aluminized, or you can get them in stainless. Also I think thats why flowmaster has come out with the diamond plate style muffler cases for off roading purposes, but I will agree with you that as far as ANY muffler taking a blow by a rock, it will smash it. And I would think your F150 friend must have gotten a used one or an old one, but I would think flowmaster wouldn't have the popularity they do if all of their mufflers only lasted 8 months before rusting out, I would guess maybe the condensation that usually leaks out the tailpipe is somehow getting cought in the muffler, sitting in there and rusted it out. I have had mine for 9 months now that I bought USED and not a single sign of rust...
1992rs/ss
Jan 31, 2025 05:10 PM
Vintageracer
Jan 10, 2020 05:33 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Navy8125
Aug 25, 2015 08:25 PM
midias
Aug 22, 2015 01:42 AM
