High flow cats
Old Apr 26, 2007 | 02:27 PM
glennjamin48's Avatar
High flow cats
When I turned on my car today I heard a loud rattling. After inspecting it I noticed it was coming from within the cats. I am pretty sure they are about to go and was just wondering what company makes the best high flow cats for an 89 5.7l formula with dual cats.
Old Apr 26, 2007 | 02:35 PM
92BLKL98's Avatar
Car: 1992 Black Z28 Hardtop
Axle/Gears: 2002 10 bolt w/3:23
Re: High flow cats
Random Technology (expensive), Catco, Dynamax, Pypes. Look at Summit. Many choices
Old Apr 26, 2007 | 02:36 PM
Re: High flow cats
In company in particular that is better or better bang for the buck
Old Apr 26, 2007 | 03:09 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
Re: High flow cats
How much of a performance gain can you expect with a high-flow cat over one from the factory?
Old Apr 26, 2007 | 11:40 PM
92BLKL98's Avatar
Re: High flow cats
I definitely felt a difference going from the factory cats to Random Technology Cats, but damn they are expensive. At 180.00 each you don't want to keep smoking them out like I did. I had a leaky injector on the left bank and ruined one Random Tech. cat. They replaced it under the warranty but said I needed to fix the problem. I ultimately smoked them out again after I replaced my injectors and weak fuel pump with a Walbro pump and my AFPR was set too high running the engine too rich again. I now have Pypes cats installed. I like them because they are so small only 4" in dia x 7" installed length, price was right too. Check out http://www.rpmoutlet.com/musv8maccat2.htm at the bottom of the page.
Old May 1, 2007 | 02:53 PM
VA1991Z28's Avatar
Car: 1991 Z28
Transmission: 5-spd
Re: High flow cats
Carsound makes high flow cats & 2 1/2 stainless Y-pipe for duel cat cars.
Old May 1, 2007 | 07:51 PM
patgta's Avatar
Re: High flow cats
magnaflows are pretty good and cheap from what i have heard and read.
pat
mud runner
Nov 2, 2015 07:30 PM
corey8084
Sep 17, 2015 02:56 PM
Stroopwafel
Sep 11, 2015 06:38 AM
89fast5oh
Sep 8, 2015 09:55 AM
Stryker412
Sep 7, 2015 09:11 AM
