True duals
Car: 90 Camaro RS
Engine: 6.3L 383 V8
True duals
I'm going to post some pics of my 2 1/2inch duals. I used the hedman S-extensions, 2 1/2in straight pipe and moroso spiral flow mufflers. Headers are Hedman 1 5/8prim. and 3 in. collector.
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
Re: True duals
I just installed my headers yesterday and I was wondering what I could get to make it around the tranny cross member. Do you have a part# for the s pipe and does it clear well ??
Car: 90 Camaro RS
Engine: 6.3L 383 V8
Re: True duals
The part number is HED-18700 from summit racing. They are the ball and socket type. They do carry other collector styles. The s-pipes come right under the crossmember. From there I ran the straight pipe. Someday I'll use mayber a smaller and shorter s-pipe to tuck it up little more. Right now I've got about 4in of clearance.
Car: 1984 z28
Engine: 355
Re: True duals
Westman, what did you use for the powersteering bracket ?? I dont want to hack mine an dmake it look like crap is the a new powersteering bracket you can buy to clear the larger primary tubes ???
Car: 90 Camaro RS
Engine: 6.3L 383 V8
Re: True duals
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: True duals
Just use threaded rod for that header hole and run 3 nuts. One nut against the header, one right before the bracket and one right after the bracket to tighten it against the first nut. Works great on all the serp. cars that I've put headers on for people.
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
Car: 1982 Camaro
Engine: 454
Transmission: TH350
Axle/Gears: 410
Re: True duals
Here is some photos of BBC mod.. may give you some ideas..
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
Car: 1984 z28
Engine: 355
Re: True duals
Thats the thing I tried to find a new bracket from hedman or hooker but nobody makes a cheap one. Everything is like $80-$120.
Car: 90 Camaro RS
Engine: 6.3L 383 V8
Re: True duals
Um.. You could say "Very Noticable". Not as loud as the glasspaks on my truck, but much louder than my single aerochamber.
