need some pics of duel 3.5 exhaust
Old Jun 12, 2007 | 09:24 PM
91camaross's Avatar
Car: 91 camaro
Engine: 421ci sb2.2
Transmission: th 400 w brake
i need some pics of how its done every exhaust shop i go to has said it cant be done with out cutting up the floor
Old Jun 12, 2007 | 10:16 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: need some pics of duel 3.5 exhaust
the only way i can see 3.5inch true duals is dumping them before the axle on a race car with tall rear tires...else you wont have much ground clearance... but you really dont need 3.5inch true duals. thats probly for cars pushing over 1000hp or something
Old Jun 12, 2007 | 11:18 PM
5678TA's Avatar
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
100%.. 3.5" duals is not a small exhaust and is not needed until you are in the low 10-high 9 second range.. a 3" dual will take you a LOOOOOOONG way.. dont even argue the topic until you have your car making 700+rwhp..
Old Jun 12, 2007 | 11:21 PM
jimdutro's Avatar
Car: 1988 Iroc
Engine: 383 TPI
Axle/Gears: BW 9 bolt 3.27
Look under exhaust in tech, I have seen pics of 3" and if you don`t want your exhaust dragging on the ground, I don`t think you can go larger.
Old Jun 12, 2007 | 11:25 PM
91camaross's Avatar
Car: 91 camaro
Engine: 421ci sb2.2
ok my car is a low 9 sec car it is a 421 with sb2.2 heads so i do need it the motor should push out in the rang of 750hp
Old Jun 12, 2007 | 11:43 PM
jimdutro's Avatar
Car: 1988 Iroc
Engine: 383 TPI
Did`nt know that. Where do you drive it?
Old Jun 12, 2007 | 11:48 PM
91camaross's Avatar
Car: 91 camaro
Engine: 421ci sb2.2
mostly the track but i do drive it on the street some times and i dont care if i have to dump it b4 the rear
Old Jun 12, 2007 | 11:56 PM
5678TA's Avatar
Car: 1984 Trans Am
oh wow.. cool.. learn something new everyday.. well since you put it that way, i would just follow the frame rails inward then the edge of the trans tunnel and dump by the u-joint
EDIT: please, do post pics of your motor.. i wanna see that..
Terrell351
Jun 13, 2021 01:13 PM
Steven 86IROC-Z
Car Audio
16
Sep 7, 2015 08:05 AM
formula_novice
Sep 5, 2015 03:58 AM
downsouthboy
Aug 29, 2015 11:29 AM
Nj1987
Aug 19, 2015 08:26 PM
