Headers
Old May 27, 2007 | 07:49 PM
MattSloc's Avatar
Car: 1986 Camaro Iroc-z
Transmission: 700r4 w/ custom shift kit
Headers
are there any headers out there that will fit my 86 camaro 305 tpi and the stock exhaust for a good price + a good boost
Old May 27, 2007 | 08:26 PM
subliminal's Avatar
Re: Headers
Do a search before you post asking a question, also the information you need is a sticky thread at the top of this section.
Old May 27, 2007 | 08:52 PM
irocz2889's Avatar
Car: 89 iroc z
Engine: tpi
Re: Headers
depending on how cheap you want to go stock exhaust manifolds for 89 irocs are larger than years prior
Old May 29, 2007 | 06:45 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Headers
Not exactly true. Check the following link for more info on exhaust sizes:
https://www.thirdgen.org/forums/exha...-question.html
JamesC
Old May 29, 2007 | 08:28 AM
MattSloc's Avatar
Re: Headers
See i'm looking for headers because i bought remanded heads for my 305 tpi and the manifold on the passenger side wont match up anymore which is wierd because only 1 bolt is off by an inch.... i posted another post about this and i was told to get headers and a friend of mine told me to do it too..but im lost on which to get so i dont have to go through the process all over again...
also...headers that will match up to stock exhaust and all the other emission control bs
Old May 29, 2007 | 09:24 AM
JamesC's Avatar
Re: Headers
The following direct-fit system should fit your requirements:
Hooker 2055's (Jeg's 520-2055). Catco high-flow converter (Summit CTO-9118). Hooker catback (Summit HOK-16823HKR).
JamesC
Old Jun 3, 2007 | 08:14 PM
MattSloc's Avatar
Re: Headers
would the 2055's generate so much heat that i would have to replace the spark plug wires and put in a special kind with a special kind of spark plug...and what about the sensors??
-thanks
Old Jun 3, 2007 | 08:51 PM
JamesC's Avatar
Re: Headers
None of those have been a problem for me so far.
JamesC
Old Jun 4, 2007 | 01:55 PM
Stephen's Avatar
Car: 87 GTA
Re: Headers
Just make sure that the plug wires are routed as far away as possible, from the headers.
NZKnight
Oct 15, 2015 02:47 PM
redformula88
Oct 14, 2015 06:08 PM
Bradsaundry
Oct 7, 2015 04:35 PM
91 SrS
Oct 7, 2015 04:32 PM
Bigold4x4
Sep 28, 2015 05:21 PM
