Finally have 3" true duals
Old Sep 27, 2008 | 10:41 AM
  #51
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Re: Finally have 3" true duals
I was planning on emailing the video from the phone to my email and then go from there.
I suppose I need to set up a photobucket account.
Old Sep 27, 2008 | 11:23 AM
  #52
firebird896's Avatar
Car: '89 GTA/'86 TA/98 TA
Engine: 350/350/LS1
Transmission: R4/T5/4L60E
Axle/Gears: 3.23/2.77/3.73
No thats ok if you want to do email thats cool
Old Sep 27, 2008 | 03:21 PM
  #53
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
email sent.
Old Sep 27, 2008 | 07:20 PM
  #54
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
Transmission: TKO-600 5 speed
Axle/Gears: 3.73 10 bolt
i really wish there was a sticky somewhere saying buy headmans not hookers. Seems to me you get way better ground clearance with the hedmans then the hookers, despite the minor inconvenience of having to bend them with a manual transmission.
I have my hookers run around a spohn crossmember and past the ds safety loop into a Y pipe and honestly the collector is every bit as low as any other point of the exhaust system. And with a 700 dollar price tag its kind of hard to just throw them in the garbage and get a set of hedmans
Old Sep 28, 2008 | 07:32 AM
  #55
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
My collectors are nearly the highest point of my exhaust. A couple of weeks ago I brought the car into a different custom exhaust shop to see if they could give me a bit more ground clearance. They told me "that's all you're going to get" I say BAH! More can be had.
Old Sep 28, 2008 | 12:27 PM
  #56
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
So we going to hear this BAD **** or what?
Old Sep 29, 2008 | 03:48 AM
  #57
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
firebird896 has the clip right now. I personally don't think it's a good clip but then again my desktop sound system is currently down. It doesn't sound right on the phone or on my laptop.
I may be in the market for a camcorder.
Old Sep 29, 2008 | 03:25 PM
  #58
Engine: 350/350/LS1
CAMCORDER CAMCORDER CAMCORDER...lol
ill post up the video if you want me too
Old Sep 29, 2008 | 06:33 PM
  #59
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
If the sound quality is that bad i'll get a camcorder. Just delete what I sent you.
Old Sep 29, 2008 | 08:42 PM
  #60
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
Originally Posted by stage20
thats a sweet setup.
you mod the floor pan any to tuck the mufflers up, or do they hang low. i cant imagine there being much ground clearance there at the mufflers.
i like the way you ran the pipes.
what mufflers are those?
The rear seat pans have been massaged to make room for the mufflers. Nothing that couldnt be returned to stock with a big rubber mallet. They are magnaflow mufflers. Here they are in action...
http://www.youtube.com/watch?v=TW60FldfiSs
here are pictures of how low the duals hang....
Old Mar 29, 2009 | 08:21 AM
  #61
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
http://www.youtube.com/watch?v=0YTypICYdi8
Forgot that somebody took a video clip. If this doesn't work then do a search at youtube for: Thirdgen Fest 2008 GTA Leaving
Old Mar 29, 2009 | 08:46 AM
  #62
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
you are definitely a man who walks the walk and not just talks the talk.
one of the finest dual systems with a great suspension i have ever seen.
Old Mar 29, 2009 | 08:57 AM
  #63
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Thanks for the props.
My whole intention was to build a sleeper. I believe I accomplished that when I pulled up to thirdgenfest and heard that many thought it would be in the "stock" class.
Unfortunately it's hard to sleep with so much noise.
Maybe when I leave this year i'll see if I can lift the front end on regular streets and drag radials.
Old Mar 29, 2009 | 12:04 PM
  #64
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
stock class huh? mine is always in the stock class as well. I figure mine came from the factory with the 1ET rpo code which was the cowl hood and roll bar
Old Mar 29, 2009 | 12:39 PM
  #65
a1990camarors's Avatar
Car: 1990 rs 1992 z28 1995 jeep
Engine: no engine, 383stroker, inline 6 4.0
Transmission: none, t5, auto
im personally going with the drews crossmember when i do mine looks like the best route shouldnt have a problem then.
Old Mar 29, 2009 | 02:28 PM
  #66
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
You can take 1st stock Camaro
I'll take 1st stock Firebird
Mine didn't come with an RPO list. It came directly out of the GM Toybox.
Old Mar 29, 2009 | 02:55 PM
  #67
T4Revan's Avatar
Car: 88 Formula, 89 Firebird.
Engine: 355 V8, 2.8L V6
Damn looks good, Of course this was done a few weeks after I was down there to look at your formula. Wish I could have drooled over it in person. That reminds me, I gotta post some pics of the formula after I get the new pass. fender on, that is if it ever warms up.
Old Mar 29, 2009 | 03:47 PM
  #68
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
The exhaust was done a little over a year ago. Too bad you guys couldn't have hung around for a bit to check it out.
You should come down to Thirdgenfest this year.
Old Mar 29, 2009 | 04:05 PM
  #69
T4Revan's Avatar
Whoops, didn't notice the original post date. If things go according to I'll be at the fest.
Old Mar 29, 2009 | 05:38 PM
  #70
KITT1983's Avatar
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
awesome duals and suspenion work dude
Old Mar 30, 2009 | 09:53 AM
  #71
18inchboyds's Avatar
Car: 1985 Trans Am
Engine: vee eight
Transmission: auto
Axle/Gears: 4.10 gears
where is thirdgenfest???
Old Mar 30, 2009 | 05:13 PM
  #72
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Crete, Illinois
Old Mar 31, 2009 | 11:30 AM
  #73
RED_DRAGON_85's Avatar
Car: 85 Camaro IROC
Engine: 5.7 TPI
Transmission: 700-R4
Axle/Gears: open rear, 3.42 gears
After about 2 days of studying, I have found out that (1) 4" exhaust pipe not only out flows (2) 3" pipes but just barely gets outflowed by (2) 3 1/2" duals.
20 | 0 .76 | 0.32 | 0.11 | 0.03
25 | 1.15 | 0.49 | 0.17 | 0.04
30 | 0.68 | 0.23 | 0.06 | 0.02
well i guess it kinda speaks for itself that your test was messed up.
unless i am misreading the charts, the restriction should go up with more airflow, but it went down in each case.
besides, two 3" pipes have a higher cross section than one 4".
now, true, there is turbulence to factor in, and thats where the 3" pipes fall short, but i would re check your tests
Old Mar 31, 2009 | 11:32 AM
  #74
Car: 85 Camaro IROC
Engine: 5.7 TPI
oops, old thread
Old Mar 31, 2009 | 11:44 AM
  #75
ibmtech's Avatar
Car: 1987 IROC-Z
Engine: TPIS II Supercharged w/Nitrous
Transmission: 700R4 Probuilt
Axle/Gears: 3:73 Richmond 12 Bolt
Yes the restriction did go down.. But if you compair the result of the 3 inch to he 4 inch the restriction limits for the 4inch are less than 1/2 of the values of the 3inch. So, you can have (2) 3 inch pipes side by side and the 4 inch will still outflow both togethor. By having larger pipes you can have more volume in turn less pressure. Tests were accurate when we studied them then and they are still accurate today.
Old Mar 31, 2009 | 11:47 AM
  #76
Car: 85 Camaro IROC
Engine: 5.7 TPI
call me a skeptic then.
i would question the accuracy of the machine.
Old Mar 31, 2009 | 12:27 PM
  #77
ibmtech's Avatar
Car: 1987 IROC-Z
I thought so at 1st also. But, then it was explained to me another way. The larger the pipe, the less pressure you have but he more volume you can push. It the opposite was true, why do people get larger headers than factory tubes?? to get more flow.... All we did was test dynamic flow using everything from 1 1/2 inch to 4 inch pipes. During the test it immediately showed that (2) 3inch pipes was not able to outflow (1) 4inch pipe.. Of course you have to take in to account turbulence, frition, and heat.
Old Mar 31, 2009 | 02:32 PM
  #78
Car: 85 Camaro IROC
Engine: 5.7 TPI
I understand the P-V relationship. It's that the pressure goes up at 25 then down at 30
And again, twin 3" pipes have a higher cross section than a single 4".
Old Mar 31, 2009 | 02:59 PM
  #79
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
what will be the most quiet.
2 3" mufflers or one 4" muffler?
Old Mar 31, 2009 | 03:42 PM
  #80
Blue1989RS's Avatar
Car: 1989 RS
Engine: 3.1L + .060" overbore
Axle/Gears: 4.11, Auburn LSD
I haven't heard anyone mention the Boundary Layer. Single 4" has (3.14*4) a 12.56" circumference while dual 3.5" (3.14*3.5 + 3.14*3.5) has 21.99". So while the area of dual 3.5" is higher than a single 4", the 4" has less material for the air to cling to, making it effectively larger.
Old Jul 21, 2009 | 05:55 PM
  #81
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
http://s636.photobucket.com/albums/u...t=MOV00027.flv
Finally have a video. BEWARE: the video is 16mb.
It's around 3 minutes long. The first 2 minutes are pretty much just the car so that I have it for when I go to sell it.
BTW - does anyone know who can either bend me an intake tube or weld one knowing that it will be polished? They'll be using the temp fabbed one that you see on the car now.
4" either stainless or aluminum.
Old Jul 21, 2009 | 06:20 PM
  #82
KITT1983's Avatar
Why are you selling it and how power does she put out?
Old Jul 22, 2009 | 04:42 AM
  #83
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
I'm thinking of selling so that I can get into some other toys. I want to start playing with LSX engines. Start with a clean slate kind of thing.
It dynoed 325.32hp and 367.75lb/ft at the wheels on a local Dynojet. Using generally accepted math puts the car at 383hp and 434lb/ft at the flexplate.
I was a bit disappointed with the results.
Old Jul 22, 2009 | 05:09 AM
  #84
KITT1983's Avatar
That is still better then my ceasefire 305ci 175hp/250lbft
sreZ28
Oct 22, 2015 08:21 AM
Chevykid810
Sep 28, 2015 12:57 PM
Eric-86sc
Sep 22, 2015 08:25 PM
Camaro_383
Sep 11, 2015 11:28 PM
Djmathis123
Sep 8, 2015 08:42 PM
