Finally have 3" true duals
Old Jun 20, 2007 | 07:45 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
What a pain in the butt. Problems out the yin yang.
First off I have hedman longtubes, hedman extensions (cut down), 3" stainless mandrel bent piping, and 2 stainless works chambered mufflers.
Talk about everything getting in the way of everything else. Turns out the Spohn trans crossmember WITH longtubes is not in the slightest bit a friendly combo. My extensions had to be cut down to get around that and the "frame".
Shorties would've been much easier and given me more ground clearance but that's not the route I wanted to go.
My X-pipe was useless. Couldn't cross the pipe from the side to the other. Had to fabricate an H-pipe that goes BETWEEN the x-member with driveshaft loop and the Spohn torque arm.
After some creative bending in the front area we were finally able to run some straight pipe. At the rear it wasn't too much of an issue to get each pipe to go over the rear axle on either side of the car. Turns out I missed taking the complete rear pic but all I did was run the 3" piping out the rear. No tips. 1 3" pipe out each side. I'm thinking of running about 2" per side of 4" pipe to bring the tone down a bit. It's a little raspy at the moment BUT it was inside a metal and concrete building what it was finally started. Echoes, reverberations, don't make for a true sound.
Here are some pics. I only have 2" of ground clearance. I'm going to have to do something about that. Let me know what you think.
Attached Thumbnails Finally have 3" true duals-dualexhaust.jpg   Finally have 3" true duals-dualexhaust1.jpg   Finally have 3" true duals-dualexhaust2.jpg
Old Jun 20, 2007 | 07:48 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Re: Finally have 3" true duals
And a couple more.
Attached Thumbnails Finally have 3" true duals-dualexhaust3.jpg   Finally have 3" true duals-dualexhaust4.jpg   Finally have 3" true duals-undercarriage.jpg
Old Jun 20, 2007 | 08:03 AM
battman's Avatar
Car: 87 GTA, 88 GTA, 92 TA, 72 RS SS
Engine: 350, 350, 305, 396
Transmission: T56, 700r4, 700r4, T56
Axle/Gears: 3.42, 3.23, 3.23, 3.73
Very nice fab work I like it. I wan't to do the same on my GTA but dump right before the rear end, its turning into a track queen
Give us some sound clips!
Old Jun 20, 2007 | 09:18 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
When I get it back I will. The car's also in for a little body work and an alignment.
Old Jun 20, 2007 | 09:51 AM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
Damn man, that looks awesome! Try and get some soundclips.
Old Jun 20, 2007 | 10:07 AM
AC's Avatar
AC
Car: Used to drive a camaro
That's some nice looking work. Any worries on the pipes proximity to the hard fuel lines? What's the O.D.of your H-pipe (looks like 2-1/2") No cat's? I'd be interested in getting pics of how you came up over the axle.
P.S. I'm jealous!:
Old Jun 20, 2007 | 12:05 PM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
Holy Shnikes....that looks badass...I cant wait to hear the chambered mufflers...I will be purchasing GMMG's exhaust in a few months here. Sounds awesome....well now we wait for sound clips.
Old Jun 20, 2007 | 02:29 PM
online170's Avatar
Car: 1987 Firebird
Engine: 355
Wow, ive never seen it done like that. Guys seem to have good success with going around the spohn x-member and then sort of converging back along the driveshaft before splittling out over the axle. That way, you can hide a couple of inches up in the driveshaft tunnel.
But i think it looks awesome. However, exhausts are ALL about sound!!! Cant wait to hear it.
Old Jun 20, 2007 | 09:16 PM
Frozer!!!'s Avatar
Car: '90 RS
Engine: Vortec 350
Axle/Gears: 3.23 non posi
Looks awesome great job!
Old Jun 20, 2007 | 10:54 PM
EvilCartman's Avatar
Car: '82 Z28
2 inches of clearance? dang, I've got 3 with my dual 3 inch lol. Yeah the spohn crossmember freakin sucks for longtubes and dual. Ripping mine out sometime this year and building a new crossmember.
Old Jun 22, 2007 | 10:37 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
AC - I'm going to have to wrap my fuel lines in the rear. Just a little too close. I don't know off hand what the H diameter is.
WWD - It sounds pretty good. A little raspy at this point but it was inside a concrete and metal building with no real tuning as of yet. High idle. Definitely a cop magnet. I guess that's what neutral's for
online - Couldn't converge in the middle due to my mufflers. They're 30" long each. My original plan was to have them in the rear of the car but unfortunately 3" pipe doesn't bend that sharp without taking up a lot of room.
Here's the only pic I have of the exhaust coming up over the axle.
Track queen? Street legal track queen!!
Old Jun 25, 2007 | 04:08 AM
Ltrain925's Avatar
Car: 85 T/A
Engine: l98 ,cam,exhaust
Transmission: beefed up 700R4
Axle/Gears: 2000 ss 3.42s
all that nice exhaust and no chrome tips???
Old Jun 25, 2007 | 12:48 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Haven't decided what i'm going to do about tips yet. I'm thinking of taking off about 18" of pipe per side and bumping up to 4" in diameter. This should deepen the tone a bit.
Old Jun 26, 2007 | 08:17 AM
AC's Avatar
AC
Viprklr, one more question. The sections up and over the axle. Are those custom bent or did you use another car / app to do that? I've always wondered what other vehicles exhaust sections would make it up and over.
Old Jun 26, 2007 | 11:54 AM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
I have good ground clearance with mine. I'd even say I've got the best clearance of any true dual 3" setup on here. The only way to have good ground clearance is to keep the pipes tucked up in the tunnel like this....
with only 2" of clearance you will destroy all that pretty work once you start driving the car. 2" is just not enough.
Old Jun 26, 2007 | 01:50 PM
Car: '82 Z28
Your way is impossible with a Spohn crossmember.
Old Jun 26, 2007 | 06:25 PM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
well I have not been under a car with Spohn's monstrosity hangin underneath it, so I dont know how much room there is for pipes. I would have to say that if I had that jungle jim hanging under my car I'd run a single 4" exhaust. His true duals are just totally unacceptable as far as ground clearance is concerned. I like the craftsmanship, but in my opinion, that is NOT a setup that should be created for use on the street, and I think we need to make sure people know that before they think that is the hot setup.
Old Jun 27, 2007 | 12:39 AM
Car: '82 Z28
Even just doing a single 4" the problem is getting around that POS crossmember. That's where a lot of ground clearance is lost. On mine I only have 3 inches at the lowest point which is right where it goes around the crossmember on the driver's side. Going to eventually make a new crossmember that should allow me to move the exhaust up 1.5 inches.
Old Jun 27, 2007 | 04:48 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Custom bent.
I agree with Cartman. There are 2 major differences between your setup and mine. 1 I have the Spohn X-member. That's the biggest difference. 2 you have a manual I have auto. The T-5 is much smaller than the 700.
I also do believe that 2 inches is unacceptable. I plan on taking the time in figuring out a way to raise the pipes to get at least another inch. It will be hard to find that kind of room though.
Old Jun 27, 2007 | 07:38 AM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
I think they look great and probably sound even better. I have had people in the past tell me how hard this was to do.
Old Jun 27, 2007 | 11:54 AM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Originally Posted by Viprklr
Custom bent.
I have a TKO600, check the sig. It is at least as big as a T56 and it rides 2" lower than a T5.
I mis spoke earlier when I said I'd run a single exhaust with the Spohn cross member. I meant to say that I'd not run long tubes with that cross member, because no matter what you do with long tubes Y pipe or duals, you have to deal with the cross member. With with a complicated setup like that I'd just run the 1.75 SLP shorties and move on with life and enjoy better ground clearance. Long tubes really put you in a pinch if you dont have a good place to route the rest of the pipes.
Old Jun 27, 2007 | 03:35 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
That's a TKO600? Sure looks tiny. My 700 fills up the whole tunnel.
I sorta agree with you on the shorties but remaining 2 separate pipes and running down the stock location. But not all of us want to run shorties. For my application I wanted LT's. I sacrifice ground clearance but then again the roads are fine where I live. All I have to watch out for is roadkill. Country roads tend to have a lot.
Old Jun 28, 2007 | 02:21 PM
Dima's Avatar
Car: 2002 Pontiac Firebird (R.I.P 1992)
Engine: 3.8L Ram Air V6 3800 Series
Transmission: 5spd
Axle/Gears: Unsure
Dam so now I guess I know what dual cat is... well true dual :P seperate pipes from each header, seperate mufflers, etc, thats sick as hell wish i could do that to mine sometime in the future =/
I WANT YOUR SUSPENTION TOO! god that is just so neat looking
Old Jun 30, 2007 | 08:18 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
I went a little overboard.
Old Jun 30, 2007 | 04:10 PM
shocker89bird's Avatar
Car: 89 ws6
Engine: 355 afr195, hsr,gmpp cam, hs rr,
Transmission: t-5
Axle/Gears: 3.08
Looks good I am sure it sounds nice too. Ground clearance will be a huge issue for your car. Stock springs may help but try to see if you cna tuck it up higher.
Old Jun 30, 2007 | 09:37 PM
Dima's Avatar
Transmission: 5spd
Axle/Gears: Unsure
How did you go about all that? Just order every single piece from sphoon and install yourself or did you have someone else do it O_o Cause once I'm done with the basics I wanna start getting upgrades over the next few years hah and suspention is on the list!
Old Jul 2, 2007 | 08:17 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
I'm sitting on new stock springs. Tucking it up a bit more is priority number 3 on my list.
Yes. Ordered and installed myself.
Built, not Bought.
Old Jul 11, 2007 | 09:21 AM
bowtienick's Avatar
Car: 1991 rs, 1992 z/28
Engine: 363 ci chevy sb
Transmission: 700-r4
based on 1meanZ's exhaust pic, i think this system, magnaflow 3" kit for 1967-73 camaro, could be adapted, maybe cut in a couple of bends to tuck it up like his.
Old Jul 11, 2007 | 03:09 PM
1320_Guy's Avatar
Car: 89 RS
Transmission: th350
I have about 2.5" of clearence with me out of the car, never had anyone look wile i was in it. I scrape ALL the time. I even scrape pulling through the water hole at the local track.
I am going to redo it soon and try and get more clearence.
Old Jul 11, 2007 | 03:55 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
That's how I did mine, with the H pipe behind the driveshaft loop.
Old Jul 12, 2007 | 11:21 AM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Actually its just hedman S-extensions, a couple 3" elbows and 2 lengths of pipe with Magnaflow mufflers. The magnaflow mufflers are awesome by the way.
Old Jul 12, 2007 | 03:41 PM
vic_V8's Avatar
Car: RS
Transmission: 4L60
viprklr, where are you from? I have to check this thing out, Dixon here.
Old Jul 27, 2007 | 04:28 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Sorry it took so long. You posted when email notification was down.
I live in Capron. It's about 1 hour 15 minutes from you, ENE of Rockford.
Old Jul 27, 2007 | 06:36 PM
Badass355ciz28's Avatar
Car: 1983 CHEVROLET CAMARO Z28
Engine: Forged 355 with a GT45 turbo
Axle/Gears: built 4th gen rear with 3.27s
2" clearance is real tight i would be a lil irritated goin over speed bumps and what not i had plenty of ground clearance before i lowered my car 2"
this is with 2 1/2 duals
here is a link to mine you might get some ideas who knows
https://www.thirdgen.org/forums/exha...-2-5-dual.html
Last edited by Badass355ciz28; Jul 27, 2007 at 06:38 PM. Reason: Automerged Doublepost
Old Jul 28, 2007 | 01:29 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
I've gotten mine up to 2 1/4" ground clearance now. I don't believe i'll be able to get more than maybe a total of 2.5"
2.25" should be enough for driving but i will definitely have to avoid speed bumps.
Old Jul 28, 2007 | 02:00 PM
Gottork1967's Avatar
Car: 83 Firebird
Transmission: 2004r
Axle/Gears: 10 bolt posi 3.08
HOLY AFTERMARKET SPOHN FEST BATMAN!!!!!!!!!!!!!!!
NICE!!!!!!!!
Old Jul 28, 2007 | 02:20 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Thanks!
Old Jul 28, 2007 | 02:31 PM
ibmtech's Avatar
Car: 1987 IROC-Z
Engine: TPIS II Supercharged w/Nitrous
Transmission: 700R4 Probuilt
Axle/Gears: 3:73 Richmond 12 Bolt
That was very nice work on the dual exhaust..
I know that I am going to alot of discussion on this. But, I will say it anyway.. There has been alot of discussion and we have flowtested numerous exhaust systems to see what flows better. Either (2) 3" exhaust pipes or (1) 4" pipe..
After about 2 days of studying, I have found out that (1) 4" exhaust pipe not only out flows (2) 3" pipes but just barely gets outflowed by (2) 3 1/2" duals.
But, after talking to numerous tech's from Mufflex, PYPES, Edelbrock .. 4" piping is designed for 800+ hp.. I know 3rd gen cars that are running 4" exhaust and they claim they don't notice any lack of power. If you run large exhaust it sounds great but you are probably going to lose low end torque.
Old May 30, 2008 | 09:28 PM
firebird896's Avatar
Car: '89 GTA/'86 TA/98 TA
Engine: 350/350/LS1
Transmission: R4/T5/4L60E
Axle/Gears: 3.23/2.77/3.73
So ah wheres this video. I was at TGO fest when u reved and blasted off. I need to here that eardrum breaking sound again
Old May 31, 2008 | 09:22 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
I still don't have the means to record any video or sound clips. The 3 that were taken at the fest are pretty good.
Nothing like the real thing though.
Putting the rest of the exhaust on didn't really make it too much quieter than running it with the open headers.
As an update for the rest of the thread.....I did put the 4" by 18" long tips on (as you saw) and it did deepen the tone some.
Old May 31, 2008 | 11:53 AM
Engine: 350/350/LS1
Thats true. It was just amazing. Come zip by my town and blast those things off. Watch out for the Barney Fifs though
Old May 31, 2008 | 01:09 PM
  #42
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
Looks really nice, now sand and paint that rusty floor pan!
Old May 31, 2008 | 01:30 PM
  #43
Tobias05's Avatar
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
kudos to those of you fighting the dual exhaust monster, i ended up giving in and bought some hooker 2055s and threw my cat-back back on!
Old Jun 1, 2008 | 08:57 AM
  #44
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
I enjoy the sound. So far no cops have pulled me over for a closer listen. I'm sure that'll eventually happen as tuning progresses.
One of these days i'll have to borrow my buddy's lift to take care of the undercarriage. In the meantime it doesn't see anything less than dry clean roads.
Old Jun 4, 2008 | 07:22 PM
  #45
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
thats a sweet setup.
you mod the floor pan any to tuck the mufflers up, or do they hang low. i cant imagine there being much ground clearance there at the mufflers.
i like the way you ran the pipes.
what mufflers are those?
Old Jun 5, 2008 | 04:35 AM
  #46
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
A manual tranny (smaller) and the stock trans crossmember would've made it a lot easier for me to get ground clearance like this.
As it is, I think another inch could be had on mine. One of these days i'll have to rip into it again.
Old Jun 5, 2008 | 05:58 AM
  #47
ibmtech's Avatar
Car: 1987 IROC-Z
There has been alot of conversation about 3" dual's ~VS~ 4" single. I have checked flow test numbers on pretty much all of them before I went to Mufflex. Here are the results of our study.
Air By | 2" | 2.5" | 3" | 4"
Volume
20 | 0 .76 | 0.32 | 0.11 | 0.03
25 | 1.15 | 0.49 | 0.17 | 0.04
30 | 0.68 | 0.23 | 0.06 | 0.02
You can see that a single 4" pipe has less than 1/3 the restriction than a single 3" and would outflow almost 1/3 times as much dual 3" combined. During the test we also checked (2) 3 1/2" pipes and it was almost the same flow numbers as a single 4" pipe.
We get these numbers by calculating psi, by multiplying feet of head x .4335
Old Jun 5, 2008 | 08:02 AM
  #48
smgseanmicheal's Avatar
Car: 86 z28
Engine: 305ish
Transmission: 700r4-kickdown cable
Axle/Gears: ill figure out when i pull it apart
i just got an idea but not sure if its street legal run them out right behind ur doors and i think thatd look nice on a camaro but not sure if theres enough room and it melted the plastic on my friends truck ... wait camaros are made of metal wait the ground effects arent nvm... any help on this idea? its kinda a stupic crazy idea but id like to try it cause i got 10 months to work on this before i drive
Old Sep 27, 2008 | 08:20 AM
  #49
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
The wife finally got a phone that takes video's with sound. I'll record a small clip of it today. How would I go about posting it on the forum?
Old Sep 27, 2008 | 10:22 AM
  #50
Engine: 350/350/LS1
Oh boy, I dont do the cell phone thing, But if you have a camera, upload it to your computer then upload it to photobucket if you can, thats how I do it
