Need help with headers for 89 305
Old Jun 24, 2007 | 02:49 PM
RS-Chevy-SS's Avatar
Car: 1989 Chevy Camaro RS
Engine: L30 TBI 5.0L Vortec
Axle/Gears: Stock
okay guys I have a 89 RS 305 TBI with the 3" catback including the 2.25 inch inlet cat with 3" outlet but I want more power...What do you suggest for headers and such...also do i need to have the air tubes on the headers like the manifolds?
Old Jun 24, 2007 | 07:39 PM
DillonRager's Avatar
Re: Need help with headers for 89 305
if your car has to pass emissions you should get headers with air tubes.
Old Jun 24, 2007 | 10:14 PM
kairles's Avatar
Car: 89 IrocZ/17 LS 1LE
Engine: 383/LGX
Transmission: 400/TR-3160
Axle/Gears: 3.08/3.27
Heres a good read on this subject
https://www.thirdgen.org/forums/nort...hlight=headers
Old Jun 26, 2007 | 03:33 PM
Axle/Gears: Stock
doesnt have to pass emissions but id like it to be able to if needed...any ideas?
Old Jun 26, 2007 | 07:00 PM
blimko's Avatar
Car: Camaro RS
Engine: 305 tbi
Transmission: manual
i went with an inch and 5/8 headmen shorties 3 inch collector for headers. i wouldnt say you would have to get the ones with air tubes if your into having a better appearance as well. i would reccomend you find headers with an 02 bung already installed. the best part about putting in your headers is, putting them in. it takes some work but with common sense you can get it. i ended up pulling my steering shaft out and over, snapping off a temp sensor for the fan relay, AND removing all my airconditioning components
beastin91rs
Oct 9, 2015 07:38 AM
hectre13
Sep 8, 2015 03:38 PM
Wvcamaro
Sep 4, 2015 08:38 PM
theurge
Aug 21, 2015 12:46 PM
camaro_rs350
Northern California
Aug 18, 2015 12:38 AM
