my cataylic coverter turned bright red
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Re: my cataylic coverter turned bright red
No...but it will be if you don't fix your over rich problem.
A cat converter is an afterburner, if it gets raw fuel in it, it trys to burn it up. Hense the extra heat.
Car: 87z28
Engine: 70 LT1
Transmission: 350 TURBO BUILT BY B&M
Axle/Gears: 12 BOLT POSI
I found two plug wires that had bad ends connecting to the spark plugs would that cause the raw fuel i fixed them but should i change my cat ?
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
yes unburnt fuel from those cylinders
as far as replacing it or not well that depends
is it still flowing through and not a restriction?
it may have burnt it up so that it is not very effective, if at all
does the car idle and run ok still ? still same power as before this happened ?
exhaust out the end still feel ok ?
hard to tell for sure though
Car: 1991 Camaro RS
Engine: The Wicked six'ah
Axle/Gears: stock 3.08's
Hmm, Ive never seen a Convertor turn bright red.. I'm sure the convertor is fine.. Take the Intermediate Pipe off and look inside.. when its cool...
Car: 89 TransAm
Engine: 305TPI
Had that happen to me in a 4 banger Cavalier. It had 2 coil packs, each feed spark to 2 cylinders each. One of those packs dies, car was dumping 2 cylinders worth of fuel straight into the cat.
Replaced the coil pack and drove it for 3 more years....never caused a problem.
ambainb
Apr 25, 2016 09:21 PM
louishenry
Aug 28, 2015 09:41 AM
Eric-86sc
Aug 24, 2015 09:01 PM
