Dual Cat upgrade?
Old Jul 8, 2007 | 11:52 PM
wgripp's Avatar
Car: 1991 Trans Am GTA
Engine: L98(5.7 L TPI)
Transmission: 700r4(A4)
Axle/Gears: G80 RPO, 3:23s, Auburn Racer's Diff
Dual Cat upgrade?
I'm getting a set of Dyno Don's headers. I already have a 3 inch cat back exhaust and stock dual cats.
My engine is basically stock.
I was wondering if it was worth it to upgrade the dual cats. If so, what would you recommend?
(I've tried searching this subject, but haven't had much luck.)
Thanks!
Bill
Old Jul 9, 2007 | 08:08 AM
Jay's Avatar
Jay
Car: 88 IROC
Engine: 5.7 RamJet
Axle/Gears: Dana44 4.10
Re: Dual Cat upgrade?
I've seen people say it makes a difference and then others say it's not worth the extra expense.
The factory setup is pretty bad after the cats with how it connects to the I pipe. Catco and Magnaflow(Carsound) offer replacement assemblies but they are not cheap.
Summit -
Magnaflow - MPE-23479 $291.95
Catco - CTO-4153 $340.39
The Catco setup has 2.5" output and the Magnaflow has 2.625" and a better after cat Y.
I personally went with a replacement 3" converter and a pair of 45* bends.
Old Jul 9, 2007 | 08:58 AM
91-RS-B4C-fake?'s Avatar
Car: 1991 Camaro B4C
Engine: L98 350 cid (5.7L) TPI v8
Transmission: 700 R4 auto trans
Axle/Gears: 10 bolt w/girdle & 3.42 MotiveGears
I went with the catco dual cat replacments from Summit.
At the time Magnaflow was on back order.
The local shop has used these before.
Fit exactly like the stock ones.
I felt it was a waste of money.
No performance gain @ all.
But then again I already had dual factory cats.
I can't prove it but the dual cats might give some improvement over a single cat.
When my car was mostly stock,
I raced a couple of L98 cars with single fatory cats
and mine was just a little bit quicker.
Not a lot maybe .05 to.1 of a sec.
Just enought to get a win on the 1/4 mile.
I say get rid of them Unless your in a smog state.
I wished I would have.
But you' ll need to cut them out yourself, once the
Shop had seen my car with them on they wouldn't
take them out.
They'd only replace them.
Last edited by 91-RS-B4C-fake?; Jul 9, 2007 at 09:12 AM. Reason: needed more proof reading.
Bubbajones_ya
Jul 6, 2024 08:32 PM
mud runner
Nov 2, 2015 07:30 PM
customblackbird
Oct 1, 2015 04:30 PM
Camaro_383
Sep 11, 2015 11:28 PM
Djmathis123
Sep 8, 2015 08:42 PM
