Does This Y-pipe even Fit??
Old Jul 12, 2007 | 08:08 PM
HiPerf_Chevyman's Avatar
Car: 1991 Camaro RS
Engine: The Wicked six'ah
Axle/Gears: stock 3.08's
I bought This Y-pipe, http://www.jegs.com/webapp/wcs/store...0002_744775_-1 To match these Headers, http://www.jegs.com/webapp/wcs/store...10002_16730_-1
I know the Inlets on the y-pipe is 2.25" and the header outlet is 3.00" once i got them. However theres these two Reducers that fit the 3'' ball flange and then it reduces to 2.25 and then runs a straight 2.25" for about 2 inches.. However you cannot fit a 2.25 Pipe in a 2.25 hole.. so am i suppose to cut that extra straight part of the reducer off? theres like 6, 2.5" long bolts for the flanges, so I guess those two reducers are for my application???
I Dont know where to go with this...
Old Jul 13, 2007 | 05:05 AM
Car: 1991 Camaro RS
Re: Does This Y-pipe even Fit??
Has Anyone here Bought this Y-pipe?
Old Jul 13, 2007 | 11:11 AM
86irocu's Avatar
Car: 1986 Iroc-Z
Axle/Gears: 3.73 posi
which Y-pipe did you buy? If you bought the one with the ball flange on the ends that attach to the headers then it will work with no cutting or sizing needed. I bought the same headers and Y-pipe for my car. The Y-Pipe should come in 2 pieces. (not counting the rings/bolts that are used to attach the headers) They make the Y-pipe so it adjustable on the drivers side of the car. I'm really not quite sure what you are asking, maybe elaborate a little more or show some pictures??
Old Jul 13, 2007 | 12:41 PM
Bigseth's Avatar
Car: 86 Iroc 383 carb, 97 T/A WS6
nevermind.
Old Jul 14, 2007 | 09:57 PM
Car: 1991 Camaro RS
the Y-pipe flanges do not fit the 3" Header Flanges, I mean it would leak hardcore... Did you get Two Reducers? Kinda Cone Shaped?
Old Jul 15, 2007 | 12:31 PM
86irocu's Avatar
Car: 1986 Iroc-Z
what is the model number of the hedman headers again? and the model num for the Y?? Mine has 3" flanges comming off the header and i do not have any leaks.
Old Jul 15, 2007 | 02:03 PM
Car: 1991 Camaro RS
My Y-pipe has 2 1/2'' collectors the headers have 3'' collectors..
Old Jul 16, 2007 | 04:46 PM
86irocu's Avatar
Car: 1986 Iroc-Z
is it a ball type flange on the end of the header? the flange on your Y-pipe should open up to over 3 inches.
Old Jul 16, 2007 | 08:48 PM
Car: 1991 Camaro RS
Yea thats the problem, The y-pipe Doesnt open up more than 2 3/4, I got a 3'' to 2.50'' reducer and flared one end while rolling the other end.. which actually gave me 2'' between the oil pan and y-pipe, ground clearance is great..
New2Chevy
Sep 28, 2015 12:35 AM
armybyrd
Carburetors
25
Sep 13, 2015 01:49 PM
turbobuick88
Wheels and Tires
Sep 8, 2015 08:27 PM
BOOT77
Sep 5, 2015 03:55 PM
Formula_88AE
Sep 3, 2015 01:47 PM
