First look at Stainless Works 1 3/4" long tube headers
Old Jul 20, 2007 | 06:09 PM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
Well I finally got my set of long tubes in from Stainless Works after about a 3 month wait
part # 82921753
82-92 Small Block 1 3/4" primaries with 3" od slip joint collector. No air tube fittings
My goal was to find something that has really good ground clearance and support major HP and will work with my AFR Eliminator heads. So far I'am pretty impressed with the quallity of the wields and bends, they are a nice header and they should be since they cost a friggin fortune.
Probably in the winter I'll go ahead and install them and see if they truely are a bolt on, lol after that I'll get them coated if they do end up working with my t-56 tranny and I like the way they sit in the car for clearence and stuff.
Here are some pic's for you guys.
Attached Thumbnails First look at Stainless Works 1 3/4" long tube headers-picture-001.jpg   First look at Stainless Works 1 3/4" long tube headers-picture-003.jpg   First look at Stainless Works 1 3/4" long tube headers-picture-006.jpg
Old Jul 20, 2007 | 06:10 PM
Tony89GTA's Avatar
Car: 89 GTA
Re: First look at Stainless Works 1 3/4" long tube headers
more
Attached Thumbnails First look at Stainless Works 1 3/4" long tube headers-picture-007.jpg   First look at Stainless Works 1 3/4" long tube headers-picture-013.jpg   First look at Stainless Works 1 3/4" long tube headers-picture-015.jpg
Old Jul 20, 2007 | 06:12 PM
Tony89GTA's Avatar
Car: 89 GTA
last ones with gaskets for my AFR 195 Eliminators. BTW plug access is awesome with these straight plug heads and headers, should have no burnt plugs wires with these.
Attached Thumbnails First look at Stainless Works 1 3/4" long tube headers-picture-016.jpg   First look at Stainless Works 1 3/4" long tube headers-picture-019.jpg
Old Jul 20, 2007 | 06:22 PM
matt_p's Avatar
Car: 1991 Z28
Transmission: WC T5
Axle/Gears: 3.73 Posi
O2 sensor bung should've been farther down the collector. Readings where it is now will be erratic since they are so close to those two primaries.
Old Jul 21, 2007 | 02:56 PM
Comp788's Avatar
Car: 1982 Z28 & 1967 RR/SS 396
Engine: ZZ383 & 375hp 396
Transmission: T56 & factory TH400
Axle/Gears: 9" ford & 12 bolt 4.10
Originally Posted by Tony89GTA
more
In the picture that showes the O2 sensor bung. There is a pin hole in the weld. Better get that fixed!
socal's Avatar
Car: 91z,97ws6,98fb,87&90jeep,05 yz250
Engine: 5.0tpi,5.7LT4,5.7LS1,4.2I6,5.7TPI,1
Transmission: t5,4l60e,
check the fit now i got a set and the driver side collector would hit the frame and not let it seal to the head and both head flanges were very warped had to send them back also had to make a heat shilde for the fuel/brake lines on the driver lower frame by the collector and when i shut down the motor they hit the frame. I thought the same about the o2 as well to close
Old Jul 23, 2007 | 02:07 PM
TexasLT1's Avatar
Car: '92 RS
I just got my Hawk's thirdgen longtubes (made by Stainless Works) without the O2 bung, will weld my own on a little farther downstream. looks like great construction though. just waiting to get my engine back from the builder now.
*Edit* ok so I didn't look at the other header, it's got the O2 bung on it will have to plug it and weld another one on
Old Oct 13, 2007 | 10:38 AM
91_Formula's Avatar
Car: 91 Formula
Engine: L98 350 TPI
Transmission: TH700R4
Hello,
I found this thread looking for info on the SS works LT headers with the 3" collector. What is everyone doing for a Y pipe? All custom? I have been contemplating getting these as I am looking for a LT header with the best ground clearance possible. Does anyone have any install pictures?
Old Nov 7, 2007 | 09:54 AM
CRAMOS78's Avatar
Car: 92 camaro
Engine: stroker
Transmission: Megaraptor
yeah , what are you guys doing for a y pipe. ive got the spohn crossmember and it does look like its gonna be easy
here's a few pics.....
Attached Thumbnails First look at Stainless Works 1 3/4" long tube headers-100_0719.jpg   First look at Stainless Works 1 3/4" long tube headers-passenger.jpg
Old Nov 7, 2007 | 09:59 AM
CRAMOS78's Avatar
Car: 92 camaro
Engine: stroker
a few more pics.....
i actually bought the y pipe to it, but the spohn crossmember is gonna be dificult to bypass. it would have fit fine w/ the stock tranny crosmember, i believe.....
atleast i have ss pipe w/ bends that ill be able to cut up and modify
Attached Thumbnails First look at Stainless Works 1 3/4" long tube headers-100_0716.jpg   First look at Stainless Works 1 3/4" long tube headers-100_0715.jpg   First look at Stainless Works 1 3/4" long tube headers-100_0714.jpg
Old Nov 7, 2007 | 10:19 AM
91_Formula's Avatar
Car: 91 Formula
Engine: L98 350 TPI
CRAMOS78 - the Y pipe you bought, is it a Y for the 3 inch collectors? Is the tubing for the Y pipe all 3" pipe?
Thanks for the photos, those are great, the ground clearence looks fantastic.
Old Nov 7, 2007 | 10:35 AM
kerplunk318's Avatar
those are TUCKED, they look awesome congrats
Old Nov 7, 2007 | 12:36 PM
CRAMOS78's Avatar
Car: 92 camaro
Engine: stroker
yeah they a pretty close to the body,
if i remember correctly they could only make their custum y pipe for the 2 1/2 collector.
thats the one i got. it comes pre-bent to clear your STOCK tranny crossmemebr, however ive got the spohn one so i have to go another route.
the y pipe is 2 1/2 until they come together and merge a 3 inch pipe. all stainless steel
i think i have picture of it
here's my car w/ the stainless worrks (hawks) long tube header.
http://youtube.com/watch?v=lMR83PUzv5o
Old Nov 7, 2007 | 12:59 PM
CRAMOS78's Avatar
Car: 92 camaro
Engine: stroker
y pipe
Attached Thumbnails First look at Stainless Works 1 3/4" long tube headers-100_0726.jpg   First look at Stainless Works 1 3/4" long tube headers-100_0724.jpg
Old Nov 8, 2007 | 07:50 AM
91_Formula's Avatar
Car: 91 Formula
Engine: L98 350 TPI
Thank you for all the photos!!!
Old Nov 8, 2007 | 10:58 PM
92RS(real slow)'s Avatar
Car: 92 RS(sold) 1989 IROC-Z
Axle/Gears: ones that turn
I did not know that stainless works made the ones for hawks I thought they were made in house guess I find out somthing new each day? do you like them was thinking about getting a set when I can finally afford some nice headers lol
Old Nov 8, 2007 | 11:15 PM
jimmy92rs's Avatar
Car: 1992 RS
Engine: 01' LS1
Axle/Gears: 10 bolt auburn pro posi, 4.10 gears
part # 82921753
so what did they charge u for the headers?
Old Nov 9, 2007 | 12:21 AM
CRAMOS78's Avatar
Car: 92 camaro
Engine: stroker
yeah these headers are made only for hawks by stainless works. they dont even have them on the stainless works website. they're expensive, but definetly the best looking/ best fitting long tube header imo. the hooker long tubes were too low to the gound on my application and got roughed up a bit and i had to ding the hellouta the number 7 primary to fit my AFR's. these fit no problem.........
now if i could just figure out the Y.........
so if u want 3/4 primary and long tubes SW is tha way to go
on price ck out the website, i think they're a sponsor here and should have a banner somewhere
Old Nov 9, 2007 | 02:06 PM
jimmy92rs's Avatar
Car: 1992 RS
Engine: 01' LS1
is your car lowered? because i was thinking of getting hookers. i dont want any ground clearance issues though...
Old Nov 10, 2007 | 12:26 AM
CRAMOS78's Avatar
Car: 92 camaro
Engine: stroker
check your motor mounts, if they are old and saggy, you might wann a replace them. i think thats why mine were so close to the ground.
also i had problem w/ the #7 primary. had to bash it in a bit to be able to get to the spark plug, but i think thats an AFR prblem by what ive read on this forum
and no my car is not lowered.........
Old Nov 10, 2007 | 11:29 AM
jimmy92rs's Avatar
Car: 1992 RS
Engine: 01' LS1
well my motor mounts are new and my car is not lowered, so hopefully i dont have a clearance problem. i would like to get the stainless works headers, but i dont want spend $800 and $300 for the y pipe. CRAMOS78, on ur afr heads, are the spark plugs angled?
Old Nov 10, 2007 | 03:18 PM
CRAMOS78's Avatar
Car: 92 camaro
Engine: stroker
straight plug.....
Old Nov 21, 2007 | 01:32 AM
CRAMOS78's Avatar
Car: 92 camaro
Engine: stroker
bump
so any y pipe/ crossmember ideas.........
Old Nov 21, 2007 | 07:56 AM
91_Formula's Avatar
Car: 91 Formula
Engine: L98 350 TPI
I have been thinking of custom tranny cross member boxed either up or down to get me by that with the passenger side coming across under the tranny tail shaft. I got sidelined with a pantry project for the wife so I haven't had a chance to get my measurements to see if I am dreaming or if it might work. Hopefully this weekend.
Been doing some research on oval exhaust pipe to help with the clearance issues too. That looks promising.
Old Nov 21, 2007 | 01:12 PM
CRAMOS78's Avatar
Car: 92 camaro
Engine: stroker
the oval tubes look like they would be the route to go, im looking at Dr. Gas. i believe the wesite is www.drgas.com
Old Nov 21, 2007 | 06:33 PM
StevenK's Avatar
Car: 91 Z28
Axle/Gears: 3.73 Hawks 8.8
Your not the only one.
My driver side collector is about 1/8 inch off the fuel and brake lines. I wrapped the header but I dont think its enough as my fuel pump keeps shutting off after driving awhile.
Now I have to pull the header, cut a whole in the frame rail and run the lines inside the frame rail to keep them from getting so hot...
Such a crappy design for so much money.
Old Nov 22, 2007 | 03:27 AM
DTL504's Avatar
Car: 84 Z28 Convertible 2 Seater
Engine: Dart Little-M SBC 400
Transmission: Pro-built Automatics 700R4
Axle/Gears: Strange Engineering 3:73
Here is a picture of my Y-Pipe w Hooker Super Comps 2210. I did hhave my #8 tube cut and re welded with a wider bend to prevent the wire burn.
Cost me $300.00 to have the Mendrel Pipe Bent Y-Pipe.
Old Nov 22, 2007 | 08:23 AM
91_Formula's Avatar
Car: 91 Formula
Engine: L98 350 TPI
DTL504: WOW, your car looks fantastic. Thanks for the photos. Which brand of torque arm is that? Also not to be a pain in the A$$ but do you have any side shots showing ground clearance? I am curious to see how the exhaust pipe relates to the height of the frame rails.
Old Nov 22, 2007 | 11:39 AM
TA's Avatar
TA
Car: '88 GTA, 90 Formula
Engine: 5.7 TPI, fed growth hormones
Transmission: 700r4 4u2?
Axle/Gears: 9bolt
Any chance that these will fit with a Milodon style 7 Quart oil pan? Has anyone tried?
TA
Old Nov 22, 2007 | 06:33 PM
CRAMOS78's Avatar
Car: 92 camaro
Engine: stroker
dtl504: wow, that y looks good......... that's a spohn torque arm and crossmember correct, hows the ground clearance on that setup, any pics???
thanks
Old Nov 22, 2007 | 08:00 PM
DTL504's Avatar
I have a Milodon 7qt Oil Pan w/ no problems. The ground clearance is not that great, but I have a few 5"-6" to spare. Some curbs I can go straight over while others require me to take the ole 45* angle to prevent draging the cutouts. This is a Spohn Torque Arm. Here is a few side pictures.
Look up front this is a Milidon 7qt Oil Pan Part# MIL-30900
Old Nov 22, 2007 | 11:39 PM
TA's Avatar
TA
Axle/Gears: 9bolt
Thanks DTL, that was exactly what I was hoping to hear.
BTW, that is a beautiful car. I hope you enter it in some car shows. Awesome.
TA
Old Feb 14, 2008 | 07:43 AM
Fast92RS's Avatar
Car: 1992 Camaro RS
Engine: 383 SuperRam
Transmission: 4L60
Axle/Gears: 3:23 Posi
Has anyone else tried these headers? Any other fitment problems? I gotta say I think Im gonna go with these headers because it seems the hooker ones have a lot of fitment issues. With the y-pipe how close is it the the trans and crossmember? Is there enough room to modify the y - pipe to fit two dynatech bullet style cats? They are 4" round and 11.5" long.
Old Feb 14, 2008 | 09:22 AM
TexasLT1's Avatar
Car: '92 RS
I've got them in the shop, but I don't have the engine finished yet so I can't say how they fit in the car. from what I can tell, they should be a great fit. my only "complaint" is lack of O2 bung on the 2nd header
you might run into space issues trying to squeeze cats in there as well
Old Feb 14, 2008 | 11:03 AM
Fast92RS's Avatar
Car: 1992 Camaro RS
Transmission: 4L60
I think it will be tight as well. I might just have to get a custom y pipe made. Mufflex is not that far from me so I would probably go there. Ive been looking at the pics that hawks has and the y pipe does tightly go around the trans pan and crossmember. I have a spohn driveshaft loop that bolts onto the trans crossmember and I dont think the y - pipe will clear that.
Old Feb 14, 2008 | 12:01 PM
91_Formula's Avatar
Car: 91 Formula
Engine: L98 350 TPI
That drive shaft loop is a beaut, but it is precisly where you want the exhaust to come across. Channeling the subframe seems to be one of the more extreme, but clean, approaches for pipe routing and ground clearence. I haven't worked up the courage to do that quite yet.
Old Feb 14, 2008 | 12:47 PM
90-irocdx3's Avatar
Car: 1990 iroc z
Engine: LSX 376 F1A
Transmission: 4l60e
Axle/Gears: 12 bolt 3.42
i am currently putting new heads and headers on my car and i ended up buying the stainless works 1 3/4 headers with a 3" collector i should have some pics of the headers installed next week.
Old Feb 15, 2008 | 10:31 PM
sweet please post some pics, and any problems you have Ive been wanting these since they first came out but just cant decide if there worth it
Old Feb 15, 2008 | 10:44 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
check his link to his webshot page... alot of nice pics in there
Old Feb 28, 2008 | 03:48 PM
Fast92RS's Avatar
Car: 1992 Camaro RS
Transmission: 4L60
Any updates yet?
Old Feb 28, 2008 | 07:15 PM
camaro590's Avatar
Car: 86 camaro iroc-z and 91 s10
OMG that is the nicest camaro ive ever seen.
Old Mar 9, 2008 | 01:20 AM
  #42
any new updates? from anyone installing these
Old Mar 9, 2008 | 06:07 PM
  #43
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
im amazed that they cant fab up a better y pipe junction.
OMG, that looks like something pacesetter puts out!
rest of it looks nice!
Old Dec 1, 2023 | 09:18 PM
  #44
Tombowman89's Avatar
Car: 88 Iroc
Engine: 388 Vortec Pro-Flo 4 Small Block
Axle/Gears: 3.77 to 1
I bought the exact same headers about 5 years ago and have them mocked up to my motor and will start the fab to making it dual with an h pipe 3” all the way back. I had issues with my driver side collector hitting the bell housing case on my T56 so had to swap to a hydraulic throw out conversion clutch setup from Ram clutches. And also had to remove the passenger side collector and will have to do the same for the driver side to point them closer to the transmission. They installed my OD bung on drivers side close to the primary’s also. I would’ve bought the full system if they even made one for the 3 “ collectors but they don’t so I bought a u weld it 3” kit from flow master and will spend a bit of time making it all fit. I also did a pan hard lowering bar to gain more room for the dual pipes over the passenger side of the rear end. I won’t say these headers are all that bad though. They clear the steering and front k member, starter and other stuff pretty well. I’ll post more later
Old Dec 2, 2023 | 08:05 PM
  #45
Car: 88 Iroc
Old Dec 2, 2023 | 08:12 PM
  #46
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Got a link to those red hose separators that you're using to organize your fuel lines?
Old Dec 2, 2023 | 08:34 PM
  #47
Car: 88 Iroc
Yeah McMaster Carr spiral wrap, it’s just used as a chaff wrap
Old Dec 2, 2023 | 08:41 PM
  #48
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Old Dec 2, 2023 | 08:42 PM
  #49
Car: 88 Iroc
Look really hard I might have some other good idea fairy stuff you like just PM though.
Old Dec 3, 2023 | 11:48 AM
  #50
TexasLT1's Avatar
Car: '92 RS
That build looks fantastic all the way around. Nice work!
jtrescot
Jun 25, 2007 01:28 PM
DTL504
Dec 19, 2005 11:54 PM
fakeyankee
May 2, 2003 07:18 PM
Ray Burrows
Dec 20, 2001 10:14 AM
