from 12.9 to 12.5 1/4mile???
Car: Iroc-z 86
Engine: 350 4bbl
Transmission: built up 700r4
Axle/Gears: ls1 4.10 posi
With only changing my exhaust system???
went from cheap 1"1/2 flowtech headers with 2.5"single dynomax catback with super turbo muffler to.....1"5/8 longtube headman, true dual 2.5" in a #11386 x design magnaflow mufler...My engine was choked big time!!!
low budget dual
great sounding free flow muffler
final product
i know its sitting low got about 3" of clearance in the back, center section about 4-5in
but a had 35kg of subframe connector while being there
for my first exhaust im happy, and by the way i didnt expect much gain from it until i saw my first slip
Seb
low budget dual
final product
.Seb
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
Re: from 12.9 to 12.5 1/4mile???
i gained 2mph from 2.5" true duals to open headers.. and .1-.2 off my ET..
Car: '92 Toyota Pickup
Engine: 22R-E
Transmission: 5sp Manual
Axle/Gears: 4:??
you could get even more power from a different headers. The exhaust you had before was just crap.
Car: 1987 IROC-Z
Engine: 310 lb9
Transmission: SEMI STOCK 700R4
Axle/Gears: 3.45 9 BOLT
flowtech headers are only good for mild applications no more than 350 fly wheel hp. but that wasn't your real problem that 2.5 " single dynomax exhaust would have been killing you top end
Car: 92 Camaro
Engine: Dart SHP 406 HSR, LE heads
Transmission: Performabuilt Level 2, Vig 3200
Axle/Gears: S60 373
wow.....i was looking around the forum and found this thread......and was gonna ask this question.......question answered....but now i have another..
SebasIroc, have you redyno tuned your car since the exhaust? or was that untuned? Also i take it you work in a muffler shop? I am interested in running this setup.... I was debating running Magnaflow or Hooker areochamber.....i was going to get hook because the muffler was ALOT cheaper but after looking at the one you used.....there is very little price difference....got me thinking.....
Car: Iroc-z 86
Engine: 350 4bbl
thanks for your reply....btw i gained about .1 in the 1/8 but .3-4 from the 1/8 to the 1/4...would have gone with hooker 1 3/4" but this is a low budget setup, and im not expert in exhaust I work in a autotrans shop. This is strait tube welded with Ubend for the curves.
for the mufler....this sound mean...deep rumble at idle...hell on earth over 3k
part number #11386, btw its an x pipe while being a mufler
Seb
Seb
Car: 1987 Trans Am GTA
Engine: 357ci Stealth Ram - Under Pressure
Transmission: Built 700r4/Pro Yank 3400 Extreme
Axle/Gears: 9-Bolt 3.27
Nice gain. I am interested in how much your MPH increased? MPH is usually a beter reflection on power in the same conditions as you can go from 12.9 to 12.5 just by having beter traction.
Car: 92 Camaro
Axle/Gears: S60 373
Sebas....can you get me more pictures......i think i might want to run this exhasut now!
Car: Iroc-z 86
Engine: 350 4bbl
mph didnt really increase 4mph....btw I have zero traction problem....i'm mounted on 28x10x16 hoosier slick....just to show....my new best 60' is 1.69 was 1.71.....new best 1/8 is 7.94 was 8.16......new best 1/4 is 12.53(30degC sunny day) was 12.83(15 degC sunny day)...both with really good track prep
89formula350b2l
witch part of the exhaust you would like to see...I dont really have more pic but could take some during the week end
89formula350b2l
89formula350b2l
89formula350b2l
Wow, That exhaust made a HUGE power difference if all other variables were the same.
I've heard that every 1mph gain is roughly about 10hp~.
Roughly 40hp gained from the exhaust. I can see that since the old system was way too small.
Car: 92 Camaro
Axle/Gears: S60 373
i would like to see where the y pipe /x pipe whatever joins at the cat converter plz
also wondering if this exhaust could work even though i have shorty headers.....maybe it will give me a lil more clearance? thanks dude!
Last edited by 89formula350b2l; Jul 27, 2007 at 05:19 PM. Reason: Automerged Doublepost
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
If your car is good enough to dip into the 12's and you had a crappy system like that, then I would expect a gain like that from a better system. You probably picked up 30+hp.
Car: 92 Camaro
Axle/Gears: S60 373
I am curious as to how my car will respond to an open exhaust like that..... .4 of a second! Wow...
Car: Iroc-z 86
Engine: 350 4bbl
+- 30hp is good for budget exhaust
89 formula....this is a true dual to the muffler....no x pipe no cat.....the muffler itself is an x pipe
for your setup I would recommend this site.. http://fbody.beater.org/ ..some of those setup help me build mine and could help you with shorti style headers
thanks for great comments
Seb
Seb
Cam28_boy
Aftermarket Product Review
Nov 27, 2001 05:38 AM
Cam28_boy
Nov 1, 2001 12:15 PM
