are long tubes worth it ???
Old Jul 29, 2007 | 10:36 AM
j88l98irocz's Avatar
Car: 88 IROC-Z twin turbo
Engine: forged 383 8-1 compression
Transmission: t56
Axle/Gears: 9in 3.50's trac loc moser axles
Is it worth the $1050.00 for the longtubes and y-pipe or should I stick with the edelbrock shortys and y-pipe? How much of a gain will I see from lt's I have a fully built 383 8-1 compression running 15-20lbs of boost procharger d1sc.
oh yea what brands of long tubes do you guys recommend I was looking at the hawks stainless steel ones.
thanks John
Old Jul 29, 2007 | 10:53 AM
Pocket's Avatar
Car: 91 Trans Am
Re: are long tubes worth it ???
My hookers fit perfectly no hammering or clearancing ANYTHING
Better than stock ground clearance
I have hedmans ready for the new GTA
$1k for headers is stupid unless you need customs built
There are ALOT cheaper ones out there that work just as good
Old Jul 29, 2007 | 11:16 AM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
From the ones I have see I'm not a fan of the Edelbrock shorty's. The question is a good one. What power is to be gained going from shortys to long tubes? I don't know the answer. I would assume it will depend on the engine combination.
Old Jul 29, 2007 | 12:43 PM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
i searched on the forums and read the "important" threads at teh top. they helped me. all i need now is wonderin if these headers will be good for me. http://store.summitracing.com/partde...5&autoview=sku
Old Jul 29, 2007 | 02:12 PM
5678TA's Avatar
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
you might need the 1-3/4" primary headers.. with boost, its like running high compression which will benefit the top end more.. the 1-5/8 primaries may choke your motor.. also, get something with ceramic coating
Old Jul 29, 2007 | 02:43 PM
thirdgenlover's Avatar
Car: 87 trans am
Engine: 350 TPI bored .040 over
Transmission: modified 700r4
Axle/Gears: stock spline, 3.73 Eaton posi
youll be losing some boost because you are taking more resriction out of the exhaust with headers of any kind
Old Jul 29, 2007 | 05:28 PM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
ok well i know its hard to get long tube headers in there. so is that the right kind i mean. what kind did u guys get. ill move up to the 1 3/4 then
Old Jul 29, 2007 | 05:36 PM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
that extra 1/8 inch matters that much? there is such a price diff between it. llol
Old Jul 29, 2007 | 06:53 PM
Transmission: t56
maybe I will just stick with my edelbrock tes headers and y-pipe sand blast them and get them jet hot coated
Old Jul 29, 2007 | 10:31 PM
5678TA's Avatar
Car: 1984 Trans Am
i'm runnin the 1-3/4 primaries on my 10.6:1, 385.. runnin 11.8's.. somewhere around 400rwhp.. i think the 1-3/4's would be perfect for your motor.. heck, if you put down over 600 at the wheels, you could be in need of even bigger primaries.. not tryin to make you spend money but the shorties will hinder performance on a blown motor..
Old Jul 30, 2007 | 12:28 AM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Well, i must say...with that kind of boost, you would notice a difference.
Old Jul 30, 2007 | 12:41 AM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
u mean the nitrous. lol ya
Old Jul 30, 2007 | 01:34 AM
birdsgonnafly's Avatar
Car: 87 T/A
Engine: none right now
Transmission: prob th350
those hedmans are what I ran on my SB good set good fitting my headers now are 1 7/8
Old Jul 30, 2007 | 11:09 AM
Transmission: t56
ok so what should I go with at this point. cost is not an issue.
Old Jul 30, 2007 | 12:10 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
in your case, i would without a doubt go with the hooker longtubes. from a performance aspect, they are the only mass-produced header for your car that makes sense.
however, i would not buy their overpriced Ypipe. swap crossmembers to a "double hump" style one that allows the exhaust pipes to pass thru, then have a local shop fab up a Ypipe.
if cost is not a large issue, this is a much better solution. this is similar to what i have done to my car
Old Jul 30, 2007 | 05:40 PM
Transmission: t56
where can I get the hooker longtubes?
Old Jul 31, 2007 | 01:05 AM
5678TA's Avatar
Car: 1984 Trans Am
http://www.summitracing.com
http://www.jegs.com
Old Jul 31, 2007 | 11:09 AM
Transmission: t56
thanks
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
J-money
Jan 4, 2019 09:45 AM
dmtz956
LSX and LTX Parts
Sep 7, 2015 10:16 PM
SG91camaro
Sep 5, 2015 10:27 PM
Jetmeck
Sep 4, 2015 12:29 AM
