Drivers side muffler hanger tired of the strap thing
Old Aug 9, 2007 | 10:46 PM
Jproz1167's Avatar
Car: 1982 Trans Am & 1982 Corvette
Engine: L-98 with LO-3 induction. 350 CFI
Transmission: 5 speed and vette has 700r4
Axle/Gears: 373's in T/A .. vette unknown
Ok I am on my 4th rubber strap hanger now and tired of it breaking. Has anyone ever tried adapting the metal passenger side hanger to the drivers side. or is there a specific reason GM used the rubber strap on the drivers side? .... Welding it on my pipes isn't a problem I'm more worried if using a metal hanger like on the passenger side will cause other annoying sounds or anything.
Old Aug 10, 2007 | 02:34 AM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Re: Drivers side muffler hanger tired of the strap thing
My exhaust guy has metal hangers he uses, find a good shop and your set.
Old Aug 10, 2007 | 05:36 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Which begs the question, why? Once, I understand--hey, our car's are old. Four times, however, would make me consider the cause.
JamesC
Old Aug 10, 2007 | 07:16 AM
Jproz1167's Avatar
Well, the last one lasted maybe 10-15k miles. I do notice it takes alot of pressure to push that side of the muffler up so thats probably the cause. Either way I just want to put the metal hanger on and not worry about it again.
The exhaust is a IROC 5.7 TPI from log manifolds all the way back. However muffler has been changed as well as tail pipes so it's not like it's mismatched stuff causing it. I am missing the the catalytic converter hanger, but I highly doubt that can be causing this since I see alot of cars without them on here as well. The catalytic converter is welded to the Y-pipe as well as to the catback pipe and everything from there back is welded as well with no clamps. So that eliminates things moving and causing the problem.
Well, guess I'm off to the bone yard today to find a metal hanger.
Old Aug 10, 2007 | 08:25 AM
JamesC's Avatar
That hanger might eliminate some of the stress. Here's a possible fix for that problem:
https://www.thirdgen.org/forums/exha...ger-fix-p.html
JamesC
1992 Trans Am
May 10, 2023 07:19 PM
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
kyleb24
Aug 15, 2015 08:24 AM
timonator
Aug 11, 2015 09:56 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
