flowtech headers?
Old Aug 26, 2007 | 06:02 PM
racerx520's Avatar
flowtech headers?
hey guys, its about time for me to change out my y-pipe due to rust...but i want to put headers on and i'm looking at a set of flowtech headers http://www.carpartswholesale.com/cpw...y=1&make_code=
and its 315 for ceramic coated headers...they dont have a y-pipe but it cant be that much....what do you guys think? ive never quite heard of flowtech, but it sure beats 528 for edlebrock
Old Aug 26, 2007 | 08:57 PM
89formula350b2l's Avatar
Car: 92 Camaro
Engine: Dart SHP 406 HSR, LE heads
Transmission: Performabuilt Level 2, Vig 3200
Axle/Gears: S60 373
Re: flowtech headers?
flowtech headers are better than stock, but if you plan on doing future mods (heads, cam or anything big like that), go with 1 5/8 headers..
Old Aug 26, 2007 | 09:00 PM
jonmark1985's Avatar
Car: 89' Pontiac Firebird
Engine: L03 carb Ported #87s new shortblock
Axle/Gears: 2.73 open
i have the other set, not the 1116's
If i could go back i would get the 116's because the have a matching y-pipe. But other wise they are ok for the money. I'm content with them.
Old Aug 26, 2007 | 10:30 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Flowtechs are one step above stock manifolds, and Edelbrocks are one step above those. A set of good coated headers (SLP, Hooker, Hedman), y-pipe, and install will set you back about $800. Change your catalytic converter, i-pipe and muffler first if you havent yet. Then do the headers. Everything at once should be $1100.
Old Aug 26, 2007 | 10:37 PM
racerx520's Avatar
my muffler is new (flowmaster 80 series), my i pipe is new, and i usually dont run a cat cuz i got an electronic cut out, but i have inspection in a month so i was thinking i'd get the headers and the y-pipe (cuz mines rotted) and i thought it would be dumb to get a stock y-pipe and then just change it out in a month or so...
Old Aug 26, 2007 | 10:44 PM
Kevin91Z's Avatar
Here you go:
https://www.thirdgen.org/forums/engi...ech-after.html
Old Aug 26, 2007 | 10:52 PM
racerx520's Avatar
thank you kevin, i emailed him just now
thanks again
-brian
Old Aug 27, 2007 | 11:56 AM
DLV555's Avatar
Car: 1987 Monte Carlo SS
Engine: 400 SBC
Transmission: 200-4R
Axle/Gears: 4.10
I just installed the flowtech shorties on my car last week. So far eveything seems good. No complaints.
NZKnight
Oct 15, 2015 02:47 PM
redformula88
Oct 14, 2015 06:08 PM
Bradsaundry
Oct 7, 2015 04:35 PM
91 SrS
Oct 7, 2015 04:32 PM
Bigold4x4
Sep 28, 2015 05:21 PM
