completly screwed, lakewood bellhousing and hooker LT's
Car: 1990 Camaro
Engine: 355ci
Transmission: TKO-600 5 speed
Axle/Gears: 3.73 10 bolt
well the drivers side of the hooker long tubes just will not go in
the lakewood bellhousing for my tko-600 is sooo freaking wide i just cant get past it when trying to rotate the header into place
had one side of the motor unbolted, jacked up the motor, not enough room, tried jacking up the motor with both mounts unbolted, still not enough room. Have about 3-4" of the flange that isnt past the edge of the bellhousing
wish they just made the drivers side with a slip tube for the last tube as well, id be done by now
oh the block of wood i had accross the oil, pan, SLIPPED, so crushed in the center a descent bit, guess i need to replace the oil pan too now
the ONLY way i see this going in is if you unbolted the transmission, would be by far the easiest way but i dont have the means of doing that in my driveway
Car: 1990 Camaro
Engine: 355ci
Re: completly screwed, lakewood bellhousing and hooker LT's
i got it to fit, some how, some way, had both mounts out, the motor jacked all the way up with the dist cover off, broke a couple things, but theyre in.
i dont even feel like talking about it right now, that sucked, pics to come later
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
hey man, dont feel too bad, my project has and still is a totally beach and doing just the smallest thing is a totaly PITA. This all comes with aftermarket parts and trying to make them all work together. I would love to see the pics cause im probably going to go the same route at some point.
Car: 1990 Camaro
Engine: 355ci
pics coming but theyre not interesting, the only way to get the drivers side long tube in as far as i could tell, the rearward portion of the flange has to come up beside the slave cylinder, and only way it would slide in like that, is with the dist cap off, and the motor jacked up absolutly as high as it would go
never disconnected the trans but had to loosen the bolt on the trans crossmember so the mount and tranny could slide forward all the way when the motor came up, only broke a few things too
should mention, IMO the easiest way to do this would have been at a real shop, just disconnect the trans, slide it back cause its the lip of the bellhousing thats in the way, slide the header right in and bolt the trans back up, definitly the easy way
Hotrodboba400
12-10-2019 07:07 PM
