True Duals on a TPI
True Duals on a TPI
Hello, I am new here on the forums. Anyways I own an '87 Z28 camaro with a TPI 350 (originally a 305 TPI) and I am looking to replace my exhaust that just went with true duals from the manifold back. Preferrably Flowmasters, not enough investment to replace the manifold with headers yet, but that is for the near future. Any suggestions here on where to seek out my parts or any other advice with the situation? I have looked in so many online catalogs and can't seem to find anything for third generation regarding true duals, everything is either first or second gen, and the third gen stuff is all Y-Pipe single cat with dual outlet, which is what was on mine. Is this going to be complete custom?
Car: 91z,97ws6,98fb,87&90jeep,05 yz250
Engine: 5.0tpi,5.7LT4,5.7LS1,4.2I6,5.7TPI,1
Transmission: t5,4l60e,
Re: True Duals on a TPI
yes it will be complet custom and most shops wont want to do it. but it can be done. This is a populer thread on most boards so just look around a little more. If you are going to do it, do it right the first time and get the headers. but if your like me get the high flow manifolds at least. I dont like to deal with blown manifold gaskets and mantince so i would understand but its up to you. this is a bassanie kit for an ls1 4th gen made to fit a 92 w long tubes
Car: '88 Trans Am
Engine: 5.7L TPI
Transmission: Slushbox
i believe there has been a few posts,you will need to do a search.it was about 2 years ago or so.
personally they should have put true duals on every V8 car that was intended to be a performance car!
this is my 96Z but thirdgens can do the same
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Dual exhaust is one of the most talked about topics on this board. Here, its even one of the stickies at the top:
https://www.thirdgen.org/forums/exha...l-exhaust.html
why all the trouble to run 2 pipes into a single exaust??
ambainb
Apr 25, 2016 09:21 PM
Dialed_In
Aug 20, 2015 01:45 PM
Sanjay
Aug 12, 2015 03:41 PM
