better gas mileage?
better gas mileage?
my friend from high school (he races cars and has his own 69 camaro 454 which smokes new cobras like its job) was telling me about the headers i bought and how they'd get me better gas mileage? is this true? would it be the same with my electronic dump valve? thanks guys
-brian
-brian
Car: 87 GTA
Re: better gas mileage?
Typically, headers increase air (exhaust) flow, increasing efficiency, thereby increasing mpg.
Car: 87 Black Formula
Engine: Rollercammed Lg4
Axle/Gears: 3.23 10 Bolt Locker
I dont disagree... however, I do believe that would apply on higher power use of the specific engine in question. What I mean by that is, if you really want to try hard to get lower milage, usually that would mean careful driving, as thats what offsets milage the most. Now if you do that, and seldom get your engine up in rpm's, then you'd want your car to be optimised for that driving style. And with smaller exhaust ports, you'd get greater exhaust gas velocity at low engine speeds, and hence improve your milage with that style of driving.
However, If you do alot of full throttle driving, headers might very well improve milage for that driving style. As that would improve exhaust gas velocity at high engine rpms where it is restricted in stock configuration.
Car: Building LS3, T56 Z28
Engine: LS3
Axle/Gears: Moser/ 4.11
I have Long tubes and a 4" exhaust and
Small if you are a cruiser and big (like me) if it is a car you romp on.
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
Glowsock
Sep 11, 2015 11:09 PM
MikkoV
Sep 9, 2015 04:25 PM
