Hedman LT install
Old Sep 16, 2007 | 04:20 PM
wrsjr's Avatar
Car: 1991 Camaro RS
Engine: 355
Axle/Gears: 10 bolt Richmond 3.73 posi w/ discs
Hedman LT install
I'm having problems getting my headers bolts on. I can get 5 out of 6 however there is always one on both sides that wants to go in angled. Its the 2nd bolt (back one) on #1 port & #2 port. If I put that bolt in first then the #7 & #8 will have the same problem with their bolts. Its about to drive me crazy. These are ARP bolts, Hedman LT and Brodix heads. I've already had to repair the threads on the heads.
Old Sep 16, 2007 | 04:45 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Hedman LT install
Are your headers new or used? Are you trying to tighten down the bolts one at a time, or can you get them all started with just a couple of threads?
Old Sep 16, 2007 | 05:10 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
you need to pull the headers and file the holes a little bigger, use a round file, shouldn't take long at all, just make them slightly oval in shape.
Old Sep 16, 2007 | 07:25 PM
wrsjr's Avatar
Car: 1991 Camaro RS
Engine: 355
They are brand new. Its a mute point now, I got the passenger side snugged down and I just need to find a missing bolt to finish the drivers side. They look pretty good. I have 7.5" of ground clearance. They are tucked up in there a lot better than I was thinking they were going to.
Old Sep 16, 2007 | 08:41 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The headers themselves aren't the ground clearance problem with longtubes, it's the rest of the system to get around the frame rails and crossmember.
Frozer!!!
Jan 19, 2024 04:55 PM
hectre13
Sep 8, 2015 03:38 PM
Chiknhawk
Aug 23, 2015 05:54 PM
theurge
Aug 21, 2015 12:46 PM
