long tube headers
Old Oct 15, 2007 | 10:59 AM
sickwitstick's Avatar
Car: 87 IROC-Z
Engine: under construction
Axle/Gears: stock
long tube headers
alright guys i need your help... im looking for long tube headers for my 87 iroc. for those of you with long tubes please list what brand you have, how you like them, and a part no. if possible... thanks
Old Oct 15, 2007 | 05:59 PM
customblackbird's Avatar
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
Re: long tube headers
headman longtubes
not sure of the part number i think its like 6480 or something
1 5/8 with 3" collector
i love them the only thing i dont like is that they arent ceramic coated but i didnt want to pay 500$ for headers. they fit good kinda hard to get in tho. and u have to cut a whole and weld in an 02 sensor. they tuck up alot tighter than the hooker supercomps tho so thats a big plus for ground clearance.
Old Oct 15, 2007 | 06:49 PM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
I've got the Heddmens as well and hated them. Had to dent a primary tube on the drivers side in two spots to get them to fit correctly on my 87 bird and 91 bird.
Old Oct 15, 2007 | 08:50 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
look at the stickies
Old Oct 15, 2007 | 08:57 PM
yevgenievich's Avatar
Car: numerous
Engine: ls1, others
Transmission: t56, others
Axle/Gears: 3.23 7.6"
i have hedmens, but i don't hate them, even tho i had to bend them slightly on drivers side and notch a frame slightly too
Old Oct 15, 2007 | 09:08 PM
Bigseth's Avatar
Car: 86 Iroc 383 carb, 97 T/A WS6
I just got some 2210 hookers. Look extremely nice but I dont have my motor done yet to try them out. I here there about the best fitting and there onlt $479 at advance auto
Seth
Old Oct 15, 2007 | 09:22 PM
Car: 87 TA clone
didnt have to notch/dimple my headmans at all. hookers seem to be good but everyone complains how they sit so low and dont tuck up as nice as the headmans as far as ground clearance
Old Oct 16, 2007 | 03:23 PM
Pocket's Avatar
Car: 91 Trans Am
https://www.thirdgen.org/forums/exha...vs-hedman.html
Two brands Im running right now
Old Oct 17, 2007 | 07:39 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
Hooker. Had them since 2003. They don't work well with straight plug AFR heads & Hooker's coating sucks. I had them redone by Jet-Hot.
Old Oct 17, 2007 | 07:57 PM
Car: 87 IROC-Z
Axle/Gears: stock
what exactly was in you way that made you have bend the tubes???
im thinking of getting the heddmans and im wondering (since i have a t5) have you guys heard there to be more problems with the t5 or with the auto when it comes to the fitting issues???
Last edited by sickwitstick; Oct 17, 2007 at 08:01 PM. Reason: Automerged Doublepost
Old Oct 17, 2007 | 11:17 PM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
I've got a t56, and had no problems with the collectors. I'm running an x-member with notched out of it to tuck up the exhaust. The primary tubes had to be dented to fit around where the a-arms bolt to the k-member, and that was with grinding down the k-member A LOT.
Old Oct 20, 2007 | 11:18 PM
Z28 MeTaL HeAd's Avatar
Engine: Carb'd LT1 w/ a Cam :)
Axle/Gears: Moser 9" w/ 3.75 gears
It would help if you mentioned WHAT headers you're talking about.
Old Oct 21, 2007 | 01:15 AM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
It would help if you read the f'ing thread. I haven't changed headers since my first post in this thread if that clears anything up for you.
Old Oct 22, 2007 | 04:12 AM
So you're saying you're running the Hedmens on both your cars both with a T56?
Old Oct 22, 2007 | 08:52 AM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
I don't have the 87 anymore, but I swapped the trans/exhaust over from it and yes, I ran into the same clearance issues when I put it all in the 91.
morrow
Jan 13, 2024 12:29 PM
italiano67
Dec 11, 2016 09:21 AM
92projectcamaro
Jan 18, 2016 08:00 AM
formula_novice
Sep 5, 2015 03:58 AM
86iroc z Z28
Aug 21, 2015 10:37 PM
