exhaust gasket for a square port head??
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
ive got the patriot performance 195cc aluminum heads which have the exhaust square ports and i have the headman longtubes that are circle tubes like the stock 5.7 TPI heads. on my car now i have square copper port exhast gaskets because i didnt kno wat the ports where when i got them but they dont seal worth a $*!?
so if i have square port heads and circle port headers what gasket do i get. if i get the circle port gaskets i wouldnt think they would seal the square ports on the head.
Car: 91 Z28
Engine: 383 SuperRam
Transmission: ProBuilt 700r4
Axle/Gears: G92 3.23
Re: exhaust gasket for a square port head??
i ran into this same problem a while back with my AFR heads, sqaure port heads, round port headers, tried the sqaure port gasket and it leaked, i ran a round port gasket, and it never leaked. get the round ones.
Car: 87 TA clone
thanks for the response. but wont the different square to round port diminish flow?
wow those are some impressive numbers from ur combo... i wouldnt expect that with the mild cam that u chose and the superram. who did your tuning? and wat did u pay for your rotating assembly?
my setup and what i have already is... and all i need to get is a block/rotating assembly
HSR
58mm TB
30lb SVO ford injectors
partiot 195cc aluminum heads, partly CNC chambers and mild porting 270+cfm at .60 lift
compcams XFI 280 cam. 230/236 duration at .050, 113 lobe, lift is .567/.570 with 1.6rr
1.6 aluminum full roller rockers proform
cloyes true double roller
new roller lifters yadda yadda
i wonder if i'll put out the same as u or more?
and how much u asking for the corbeau seats?
HSR
58mm TB
Last edited by customblackbird; Oct 16, 2007 at 05:34 PM. Reason: Automerged Doublepost
Car: 91 Z28
yes it will diminish the flow some, but only around the corners because the head and the header are both 1.5" but it shouldn't be that much of a problem unless you are going all out drag car.
the numbers that i pulled with my engine were from an edelbrock air-gap 4 barrel carb, and 1 7/8 headers with a 13:1 to 14.5:1 air/fuel ratio. im doing the tune myself with fuel injection, but im still working on that... takes time. i think i paid around $2200 for the short block including the balancer and they supplied me with the roller block. the reason i chose this cam if for street purpose and im in CA so gotta keep the smog guys happy, and plus it is the perfect cam for the superram.
im asking $500 for the seats, you can click the link in my signature for some pics.
Corbeau A4 Seats
Corbeau A4 Seats
Car: 87 TA clone
oh i gotcha... wat do u think u'll be pulling with the superram? i think u might lose alil vs the carbs setup cuz the superram wont have as high of a torque band. your torque i think would be close or or maybe alil higher.
still those are some good numbers from such a mild cam.
where did u purchase the shortblock from?
Car: 91 Z28
1992 Trans Am
May 10, 2023 07:19 PM
MoJoe
Sep 24, 2015 09:12 PM
NinjaNife
Aug 23, 2015 11:49 AM
Dialed_In
Aug 20, 2015 01:45 PM
