1985 Z28 Header Compatibility
Car: 1985 Z28
Axle/Gears: rusty ones
After much reading here, it seems the headers I would like for my project are the Hooker model 2055s.
Problem: Researching the said 2055s, they list as compatible with 1986 and later thirdgens; not the 1985.
I see this for other model headers as well. Compatible for 1986-90 or 86-92. (not the 85) Anyone know what the difference is? Something one can overcome?
The engine is a 305 F, TPI
Thanks in Advance,
--Calvin
Thanks in Advance,
--Calvin
Re: 1985 Z28 Header Compatibility
Not sure when they changed from the 4-bolt flange cat (which I know was used in 85) to the slip-fit version; if that was in 86, then that's what it is.
If you're changing the entire exhaust, get the whole deal for a later-model car; headers, cat, & cat-back. It'll all fit as a unit even though the pieces won't mix and match with earlier years.
Car: 1985 Z28
I do plan on replacing the catalytic converter as well as the remaining exhaust therefore I will do as you suggest and go with an 86 or later kit.
One more question answered. 999 to go.
Thanks Sofa!
--Calvin
Thanks Sofa!
--Calvin
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Here's the direct-fit system that I use: Hooker 2055's (Jeg's 520-2055). Catco high-flow converter (Summit CTO-9118). Hooker catback (Summit HOK-16823HKR).
JamesC
JamesC
Car: 1985 Z28
Looks to be at least $1000 worth of exhaust after shipping and without the jet-hot on the headers. That is probably going to be a job for the tax return time-frame.
James,
Thanks for the parts list. Are you happy with that setup? Did everything bolt on or is there any welding involved?
--Calvin
James,
--Calvin
Car: 1986 Chev Camaro
Transmission: Th350
Axle/Gears: 10 bolt 3.23 posi
does anyone know if 93-97 lt1 longtube headers will fit a 85 camaro with the old style 350 ?
Does anyone know if 93-97 lt1 longtube headers will fit an 85 camaro with the traditional 350?
