dump exhaust undercar
Old Nov 18, 2007 | 09:24 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Axle/Gears: 3.42 open diff
I can't really find the pics that I am looking for. Does anyone have pics of exhaust that is dumped under the car with a turndown with an oval muffler, just single pipe in the stock location. How is the ground clearace for a regular oval muffler, like a universal summit muffler which I am thinking about running.
Old Nov 20, 2007 | 03:46 PM
Shookum2004's Avatar
Car: 1988 Camaro SC
Engine: 2.8v6
Transmission: 5spd manual
Re: dump exhaust undercar
i wanted to do turndowns, but like... the inspection people said that it had to exit the rear of the car and not the tires...
Old Nov 20, 2007 | 03:53 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
We don't have inspections here in FL so I don't have to worry about it. Now I am just looking for a low profile but quiet muffler.
Old Nov 20, 2007 | 03:54 PM
customblackbird's Avatar
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
if they do inspections/visual insepections you cant do it. turn downs are basically illegal, with out a cat it also wont pass, but if u can run true duals with bullet mufflers u can def run a single in the stock location, for your v6 u would want a smaller diameter, like 2 1/4, the outer diameter is only like 3" i believe with a glass pack at that size so your would def have enough room, u could run it, but angle the turndown away towards the pass side at like a 45-60 degree angle (not pointing straight down)
i have dual 3" turndowns with xpipe on my TPI 350 soon to be HSR 383. im not running bullet mufflers tho, forces from summit, u would want a spiral flow/bullet muffler. and u can keep the cat !
Old Nov 20, 2007 | 04:08 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
I actually had the idea of getting a 4th gen Z28 tip and using that as a side exit tip. I want low profile like a glasspack but they just sound like poo on a V6 and they are a little too loud for me. I have thought about running duals though, I probably won't though. 2 1/2" single pipe is where I will probably stay but I might be able to get a LTs and run short duals.
Old Nov 20, 2007 | 06:13 PM
Car: 87 TA clone
dont bother with the v6, single 2 1/4 would be best and a 2.5" is pushing it. duals would kill your power. u would have to find a good spiral muffler or something.
Old Nov 20, 2007 | 06:22 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
These motors love 2.5" piping, duals are a thought but I will probably not do it. How are Borla universal turbo mufflers? As in how quiet and would they fit in the area of the tailshaft of the tranny? I need a muffler with a low profile , but quiet. I would like to get a turbo muffler, anyone know of one that is pretty small?
gta892000
Aug 11, 2019 11:16 AM
zapr
Jul 27, 2018 06:03 PM
86White_T/A305
Mar 6, 2016 01:48 PM
TBRays98
Sep 6, 2015 05:05 PM
