What kind of exhaust
Thursday im getting and exhaust system on my 92 camaro with a 305 in it....what should i get put on it..i was thinkin straight pipes all the way back with no converter..would that sound good? should i do true duel or single??
Car: 1987 Pontiac T/A GTA
Engine: 350ci 5.7 liter
Transmission: Stock GTA Tranny
Re: What kind of exhaust
With straight pipes u lose the backpressure, on my 87 with the 350 i put flowmaster 3inch from the hedmen headers back and where the cat converter used to be i put a electric y pip cut out so i can have straight pipes when im cruising but on the highway i get the backpressure and they sound great either open or closed just IMO
Car: 90 Firebird Formula
Engine: LO3
Axle/Gears: 3.08 one wheel peel
There are a few things you need to consider. Does your state require emessions testing? If they do you will want to keep your cat convertor. Also, are you buying a catback, or paying an exhaust shop for a custom bent job? Finally, do you want the exhaust to dump before the axle under the car, or to come out the back like stock?
Also, these cars came stock with a single pipe from front to back. So to get true duals, you would need to get long-tube headers or splice into your stock y-pipe. True dual exhaust will also cots alot more to bend up.
With any exhaust, straight pipe will be loud and obnoxious. It will crackle, pop, and sound like nascar coming down the road. People will call you names like *******, or hick. But persoanlly I think it sounds sick.
With either option, the combination of bends and length of pipe will give you the backpressure you need.
If you want single exhaust, I would recommend getting 3" pipe from either before or after the cat, depending on if you keep it. Have them run that back over the axle, then y-pipe it into dual 2.25" or 2.5" pipes into some nice truck tips or something.
If you want true duals, I would have them cut the y pipe in 2 locations, right before the two pipes from the left and right banks meet at that "T" intersection. Then use no bigger than 2.5" pipes all the way back to whatever you want. This can be done, but is expensive and looses ground clearence.
im having a shop do it....i think im goin to have 3in put on it and come out the back with tips on it..but i dont have a cat on right now its just a glasspack where the cat use to be, would i have backpressure problems?
Engine: LO3
should be fine. The glaspack will keep it quieter if you decide to keep that. if you run single 3" into dual 2.25 or even 2.5 with tips you should be fine. At least it will be free flowing. If worse comes to worse, and you loose alot of low end torque, you can always put a muffler in later.
My buddy had a 305 el camino with cheepo special longtube headers. Each header went into its own 2.5" pipe with a glasspack, they ran on either side of the tranny tunnel. after the glasspacks were turndowns, so there was only about 5' of pipe after each header. It was hella loud and mean sounding. And ran fine. Untill he cooked the tranny with neutral drops.
Car: 1992 Camaro RS
Engine: 305 5.0L
Axle/Gears: Stock
On my 92 camaro i just had the pipe after my cat made to 2.5 then i had that go to my flowmaster 80s series muffler to dual 3 inch exhaust. I think it sounds pretty good and a lot of people tell me it sounds good too im not quite sure how glass packs would sound on a 305.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
A couple of things to consider: Loud becomes very annoying in a short time, especially if you enjoy conversation or listening to music. Also, perhaps purchasing an aggressive-sounding, direct-fit system (including a high-flow cat) with mandrel bends and OE type hangers would be cheaper/better than a jerry-rigged system.
JamesC
JamesC
Engine: LO3
A couple of things to consider: Loud becomes very annoying in a short time, especially if you enjoy conversion or listening to music. Also, perhaps purchasing an aggressive-sounding, direct-fit system (including a high-flow cat) with mandrel bends and OE type hangers would be cheaper/better than a jerry-rigged system.
JamesC
JamesC
As for how glasspacks sound on a 305, well it will sound the same as they will on a 350 (or very similar, they are both GenI SBC). Here are some videos I found with a quick search. They are not f-bodys but it doesent matter, they usually have that same type of thing with a short section of pipe then the glasspack. At least you will get the general idea.
http://www.youtube.com/watch?v=PxezQsAZYHA
http://www.youtube.com/watch?v=h2kmvE0pxjk
http://www.youtube.com/watch?v=yoeqqG0FYYU
This is probably the best example. It is true duals, no cats, and exits in the rear:
http://www.youtube.com/watch?v=K4OPc5VQuPw
here are two more:
http://www.youtube.com/watch?v=1G18jCYUcyE
http://www.youtube.com/watch?v=0lzJga9VWJY
