Simple help needed
Old Dec 25, 2007 | 07:12 PM
90CamaroTBI's Avatar
Car: 91 Formula, 89 IROC
Engine: LB9, LB9
Transmission: 700R4, 700R4
Axle/Gears: Posi 2.73, Posi 2.73
Simple help needed
Ok I want to put an edelbrock catback on my car its a 1991 formula with a single cat lb9 auto. I need to know what size the factory y-pipe is because they sell a kit for the 2.5 and the 2.75 cars.
Also I need to know where I can get a cat to fit the original y-pipe and then exit into 3 inches for the new catback because I cant seem to find one on summit. Thanks for any help.
Old Dec 26, 2007 | 08:59 AM
91greenbird's Avatar
Car: 2012 Ram express
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
Re: Simple help needed
anyone guys?
Old Dec 26, 2007 | 10:24 AM
Engine: LB9, LB9
ok after trying to do some research I think that i want catco 4115 which is 2 1/4 inlet and 2 1/2 outlet and then get the edelbrock catback that lists for 2 1/2 pipe because after looking at a list of cats for our cars it seems they all have 2 1/2 outlets. Can somebody confirm or disagree?
Old Dec 26, 2007 | 06:47 PM
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
take the headers of the rs should be 3" collector on the y-pipe right then buy the 9118 cat and edelbrock 3" catback (the one listed for 2.75" cars)
Old Dec 26, 2007 | 10:30 PM
Engine: LB9, LB9
not ripping the rs apart keeping manifolds for now.
Old Dec 26, 2007 | 10:32 PM
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
put the manifolds on the rs
U ARE A CHODE
Old Dec 26, 2007 | 10:34 PM
Engine: LB9, LB9
what is the difference between the two kits anyway if they are both 3"?
U ARE A CHODE
too much work i just want to bolt this trash on.
Last edited by 90CamaroTBI; Dec 26, 2007 at 10:35 PM. Reason: Automerged Doublepost
Old Dec 26, 2007 | 10:37 PM
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
wells its either getting shitty 2 1/2 system now or wait and get 3" if you get that converter and catback now you'll be forced to get the bad direct fit headers or just now headers at all and edelbrock is cheaper then hooker by about 10 bucks
Old Dec 26, 2007 | 10:52 PM
Engine: LB9, LB9
both kits have 3 inch pipes thats why i do not understand the difference between the 2
Old Dec 27, 2007 | 12:08 PM
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
were the catback bolts to the outlet of the cat is 3" the other is 2 1/2" so yeah both i pipes are 3"
Old Dec 27, 2007 | 02:55 PM
Imadude_134's Avatar
Car: 1991 Camaro RS
Engine: L98 350 TPI
Axle/Gears: ZT LSD with 3.42 - LS1 brakes
I have the stock y-pipe on my 91RS, but the muffler shop welded on extra tubing to expand it to fit a 3'' catco high flow, and a 3'' edelbrock RPM catback.
When I got my L98 swapped in, the y-pipe was expanded from where the 2 pipes connect, so it is now the same size from the joining all the way to the cat.
The initial install at the muffler shop cost me like $80, and it only took less than 1/2 hour.
Old Dec 28, 2007 | 12:06 AM
Engine: LB9, LB9
does anybody know where I can get an exhaust reducer that goes from 2.25 to 3 inch? I looked around some with no luck.
Old Dec 28, 2007 | 12:15 AM
Car: 1991 Camaro RS
Engine: L98 350 TPI
If you go to an exhaust shop, they can probably fab something up for you.
Old Dec 29, 2007 | 12:02 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Here is a picture of what I did for Tim:
(A little crude but you get the idea)
Old Dec 29, 2007 | 05:08 PM
Engine: LB9, LB9
All I did for now was get a 3 to 2.5 adapter then a 2.5 to 2.25 adapter to make one adapter when put together...this way it will be ok until i get headers.
IROCZ1989
Jan 24, 2016 03:55 PM
gta90
Sep 15, 2015 04:00 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
