y pipe question
Car: 1988 firebird trans am GTA
Engine: 5.7L w/hsr
Axle/Gears: posi 3.23
y pipe question
this might be a dumb question, but its bugging the hell out of me. everyone says a 3" dia. single exhaust is perfect for a mild to moderate 350 in one of our cars. if thats the case, why can I not find a damn y-pipe that has a 3" output? they all seem to be 2 1/2". why go through all the trouble of a 3" exhaust and nice headers to strangle it all down to 2.5" right after the headers?am i missing something here? there's all sorts of advice on which pipes are easiest to cut and splice a 3" outlet into... i just have an issue buying something for around 200 just to hack a third off and splice another new piece on. seems like a waste to me
basically, does anyone just sell a 3"output good flowing y pipe anywhere that doesn't suck? i just want to buy a nice set of headers, good y pipe minus the 2.5" bottleneck and go with it.
thanks
Thunder
thanks
Thunder
Car: 83 z28
Engine: boat anchor 305 (ex CFI)
Axle/Gears: 3.23 10 bolt
Re: y pipe question
I agree, there isn't a single model out there that has a 3 inch outlet besides the famous hooker 2055 combo. And hooker won't sell the y pipe seperately, so youhave to pay nearly 500 for the headers and y pipe. I am just gonna buy the hedman set and use the trusty chopsaw and cut the portion of 2.5 off at the y and weld in 3 so that it's the correct length and proper sizing.
Cheers!!!!!
Cheers!!!!!
Engine: 5.7L w/hsr
Re: y pipe question
500? the hooker 2055 setup on summit racing is 800... way more than i am spending.
the scenario thing in your signature is great btw
Engine: 5.7L w/hsr
Re: y pipe question
the heddman is very reasonable.. thats a cheap enough ypipe i don't think i would feel bad cutting it up. thanks for the suggestion
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: y pipe question
You must be looking at the coated Hookers. Uncoated are $450 or so.
JamesC
JamesC
Transmission: 4L80E/4L80E
Another possibility to consider (especially if you're willing to modify the cat): www.summitracing.com, HED-68491, $365.95. These are the dual-cat version, have 2-1/2" pipes to each cat. Put a "Y" after them, attach to 3" cat-back. Or, dual cats, "Y" to cat-back (like stock dual cats).
Car: '92 RS
Engine: 357ci
Transmission: G-Force t-5
Axle/Gears: 4.10 10bolt mini spool
Re: y pipe question
A 2.5" y-pipe is NOT a restriction. 2 2.5" pipes will out flow 1 3" pipe all day. You gotta merge at some point. If you are merging 2 3's into 1 3 then that is a greater restriction than 2 2.5 into 1 3. The fact still remmains that unless you are at 500hp at the crank (or more) the 3 inch system is overkill anyway. But mabe I just understand how to size a system based on performance, over the look what I got or it sounds cool factor.
Car: 1984 Trans Am
Engine: Built chevy 350
Transmission: TCI Built 700r4
Axle/Gears: 3.73 posi 10 bolt
Re: y pipe question
Car: 83 z28
Re: y pipe question
3" Y-pipe and single 3" system all the way back is good for 400hp tops. I thought it would flow more and I had 375hp at the crank in my Trans Am with a 150 shot of spray on top of that. When I hit the spray with the exhaust hooked up (Hooker 2055's 3" all the way back) It felt like maybe a 50hp gain...I took the Y-pipe off right before I sold the car and hit the spray running open headers and WHAMO it felt like a 150 shot. So 400hp maybe 425 with a single 3" system at most proven! I did this test because other people on this board said 400hp at most...they was right!
Car: '92 RS
Engine: 357ci
Re: y pipe question
I should correct myself,sorry---fatfingerd the 5 --meant 400hp in prievious statment.
This according to popular Hotrodding----their numbers not some muffler company.
A 2.75” (stock) single system is good for a 310hp engine with zero loss…
A 3” Single system is good for a 370hp engine with zero loss…
A 3.5” Single system is good for a 503hp engine with zero loss…
A 4” Single system is good for a 657hp engine with zero loss…
A 2.25” dual system is good for a 457hp engine with zero loss…
A 2.5” dual system is good for a 513hp engine with zero loss…
A 3” dual system is good for a 812hp engine with zero loss…
The fact still remains that MOST of those upgrading their system are doing so to a BASICLY STOCK powerplant.....and thus a single 3" system is still overkill even with a 2.5" y-pipe. the system overall probably was not your problem 4play most likely your muffler-----what were you running?
Engine: 5.7L w/hsr
Re: y pipe question
awesome information... what horsepower rating does a 2.5" single top out at?
i don't know what my mods are going to bring my engine up to.. i am just starting out with headers, y-pipe, edelbrock intake, runners, porting the plenum.. upgrading the ignition, wires, plugs, etc. maybe a chip and a cold air intake as well as the standard suspension upgrades (subframe connectors, strut tower bar, wonder bar). i have a stock tpi 350 with a very low mileage acdelco remanufactured engine (previous owners popped it just before i bought it and had it replaced on warranty)
I just wanted to have the full 3 inch pipe so that i can grow into it without having to tear the exhaust completely apart again in the near future.
ps.. if factory is 2.75, why are all the aftermarkets 2.5?
Car: 1984 Trans Am
Re: y pipe question
Word of caution - this is butt-dyno info, not quantitative. Having "felt" the surge of power with open headers, then comparing the time slips (same day runs) to the no-surge feeling of capped headers, and seeing that the capped runs were all quicker in 60', 1/8- and 1/4-mile ET, and MPH, I'd take all of your "data" with a few grains of salt.
Real numbers according to the butt dyno though I bet car would be at least 1/2 second faster in the 1/4 mile give or take .0002 or .0003
Seriously though it was night and day difference, full exhaust was holding it back big time on the bottle!
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Re: y pipe question
This setup is good for 400+ with a 3" cat back:
PM me for details
PM me for details
hectre13
Sep 8, 2015 03:38 PM
