Rear Y-collector for dual tips
Old Jan 5, 2008 | 05:22 PM
Demon355's Avatar
I need to see some pics of some Y collector setups for dual tips. I have a Bullet muffler in my I-pipe and still want the look of dual tips. What collector is best for this? Is there one out there to buy or do I have to make it? Would it be easier to use say 2 3/4 piping instead of 3" off the Y into dual tips? Probably eh? Want all your thoughts people!
Old Jan 5, 2008 | 09:44 PM
slow_90firebird's Avatar
Car: 90 Firebird Formula
Engine: LO3
Axle/Gears: 3.08 one wheel peel
Re: Rear Y-collector for dual tips
What are you using for an I-pipe? If it is a stock shaped one, it will currently be dumping out towards the driver side. What I would do is get a piece of 3" pipe, in a 180* mandrel bend. Then, at the apex of the bend, weld another piece of 3" pipe. On the end of either of those, make some reducers by taking some short pieces of 2.5" pipe, and expand them with a exhaust expander till they slip inside the 3" pipes. Order 2 90* mandrel bends 2.5" and run the tips of your choice out.
Old Jan 6, 2008 | 02:42 AM
Demon355's Avatar
It's either do a setup that has dual tips or just run a 3" pipe off my I-pipe and run a single exit tucked away. I'd rather have dual tips but we'll see. Maybe some more info/pics/photochops?
customblackbird
Aug 15, 2021 10:16 PM
Vintageracer
Jan 10, 2020 05:33 PM
Warlocksirix
Sep 3, 2015 12:26 PM
Dialed_In
Aug 20, 2015 01:45 PM
