Powerstick dilemma
Old Jan 6, 2008 | 11:43 AM
BMAN90RS's Avatar
Car: 1999 Jeep Grand Cherokee
Engine: 4.7l PowerTech V8
Powerstick dilemma
Alright I decided to get rid of the idea of a traditional catback and go with the powerstick from chambered exhaust inc.. i would go with the 25" stick but im not sure about the diameter because my pipe is 2' 3/4" while they only offer 2.5" and 3". do you guys think the exhaust shop could make up the difference in welding or what? need some input b/c i'd like to order it today and have on next weekend.
Old Jan 6, 2008 | 12:24 PM
slow_90firebird's Avatar
Car: 90 Firebird Formula
Engine: LO3
Axle/Gears: 3.08 one wheel peel
Re: Powerstick dilemma
Where did you get a 2 3/4" exhaust lol?? I guess it must be a custom job because that is a size the exhaust shops around here dont even have!!
Also, I would order a 3" tube because a 2.5" one would be a bottleneck in your 2.75" exhaust (especially since the inside of the powersticks arent smoothe). The exhaust shop should be able to get it to work. Either they will expand some pipe, or just fill the 1/8" with weld. I have seen them do both - most custom exhaust guys are good at building up weld to fill gaps because all the aftermarket pieces people bring them that aren't the right size. I have seen them adapt 2.5" to 3" by welding lol. Really sloppy goober welds but it didnt leak or move.
Old Jan 6, 2008 | 12:58 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
L98's had 2 3/4 inch exhaust. if you go powerstick on stock tubing, just run the 3inch and have the shop open up the current tubing or pie cut the powerstick and neck it down.
i like to see more powersticks used here, they sound good and make good power
Old Jan 6, 2008 | 01:22 PM
BMAN90RS's Avatar
its a custom exhaust. from the manifolds it goes... y-pipe, madrel bent, cutout, cat, more mandrel bent, then a custom y-pipe for the duals out the back. and orr, ur clip on the catback thread of the powerstick made me decide to go with the powerstick, and you said there is a noticeable increase in power?.well thanks for your help guys im going to order the 25 inch by 3 inch powerstick and once i got it all on there i will hopefully post a vid for you guys, but i only have a digital camera to make the clip so i dunno how thats gonna turn out
Old Jan 6, 2008 | 01:32 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
yeah, any exhaust is a good increase over stock muffler. my car really opened up sound wise without the cat tho. i have the 20inch body stick. the 25 will probly be a tad quieter.
Old Jan 6, 2008 | 01:35 PM
BMAN90RS's Avatar
well i dont have a muffler to begin with. this custom exhaust basically deleted the muffler entirely but its really loud and my dad wont let me park it in the driveway until i get something that isnt as loud. but do u think i should go 20" instead? urs has a nice deep sound to it, nvm i just checked the site and i would have to go w/ a medium stick, i cant go 20 b/c that only comes in a 2.25" inlet
Old Jan 6, 2008 | 01:53 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
medium stick will be about right. it does give it a deep sound
Old Jan 6, 2008 | 01:56 PM
BMAN90RS's Avatar
ok thanks for the tips, and actually i need more insight on what to do w/ the tailpipes. it has the dual tips on each side and they are rusting so i was thinking about new tips as well. i dont know if i want to stick w/ the dual dual look or got w/ a big 3.5" single slash on both sides
Old Jan 6, 2008 | 02:02 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Yeah the medium is what i have, 20 inch body, 25inch overall length, 3inchs.
you mounting the power stick in the I pipe section behind where the cat used to be? Then it goes over the axle and splits into two and has the dual exits?
i am running the powerstick just like that. then i have it splitting over the axle into dual outlets, with 3.5inch tips. they look good. i had 3inch tips wiht the flowmaster and didnt like them, they were too small
Old Jan 6, 2008 | 02:13 PM
BMAN90RS's Avatar
yaya i thought u meant the 20inch total length, im getting the same thing then i guess. and what do you reccomend for tips b/c i want a 3.5 exit but i dont know what brand and whatever else, the shop would have to cut off the old tips and put the new ones on but i dont know if they would have enough pipe then to make it look good. thanks though for the "tips"
Old Jan 7, 2008 | 12:25 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
lol i ran summit tips, 12inch long i think they are, 3.5inch with 3inch inlet. like 42 bucks a pair
SUM-690055
Old Jan 7, 2008 | 12:36 AM
F_N_JUNK's Avatar
Car: 1991 Camaro
Engine: Morris 434 Single Turbo
Transmission: TH350
Axle/Gears: 9" Ford w/4.11's
i've tried finding these kits... anyone got a link?
Old Jan 7, 2008 | 02:32 AM
Stephen's Avatar
Car: 87 GTA
I can only guess you didn't even TRY a Google search, did you?
I typed in 'powerstick exhaust' and got.... http://www.classicchambered.com/classic/products.html
Old Jan 7, 2008 | 02:58 AM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
are you really still running stock manifolds? If you're looking for a power gain from exhaust thats the place you should start..
Old Jan 7, 2008 | 09:22 AM
F_N_JUNK's Avatar
Car: 1991 Camaro
Transmission: TH350
Actually I DID google, got the same thing as you, but I thought there were actual "CAMARO KITS" with intermediate pipes and the whole deal? I found 1 site with it and that was it, but they wanted $800+.... thats all.
http://gmmginc.net/Exhaust/orderpage.php
Old Jan 7, 2008 | 02:19 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
gmmg is kinda similar but uses two 2.5inch pipes. I think they use stainless works chambered tubes. Sweet thunder also makes chambered tubes
I think classic chambered is the only one with TRUE 3inch pipes.
There is no kit but you can install it in the intermediate pipe area and then run custom pipes out the back to retain stock tips.
else buy a SLP loudmouth and replace their resonator with the chambered tube. Get the hanging brackets relocated for thirdgens and your set. you can find used loudmouths for like 200 bucks, plus 60 for the muffler, thats a catback for under 300, not a bad deal.
Old Jan 7, 2008 | 05:20 PM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
Do you think a medium powerstick would fit in the stock location dumped? It seems like a short powerstick has the same length as the 80 series.
Old Jan 7, 2008 | 08:18 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
yeah no doubt... i was thinking of running mine under there. the 80 series and medium stick are close to same length. you can easily dump the powerstick in stock location or just run a single exit tip out the drivers side rear.
i wanted dual tips, like the 80 series dual outlet muffler, so i ran it in the I pipe and split the exhaust into 2 over the axle like the SLP loudmouth
Old Jan 7, 2008 | 08:52 PM
Car: 1988 IROC-Z
Engine: 427 SBC
Hmmmmmmmmmmm...
Old Jan 7, 2008 | 09:04 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
i can double check for you...i still have my powerstick and flowmaster 80 series laying around
Flowmaster case is 17 inch, and overall length from inlet to exit is 23inch.
medium stick is 20 inch body and 25 inch overall length and that can be trimmed easily.
so it will work you can do it!
Old Jan 8, 2008 | 06:42 AM
F_N_JUNK's Avatar
Car: 1991 Camaro
Transmission: TH350
I like that idea... also, it would work GREAT for those runing long-tube headers, makes a 3" true-dual much easier to install/fit/ and ground clearence would be sweet!!
Also, maybe put a small power-stick where the cat is now??? and then a cat-back?
Old Jan 8, 2008 | 09:38 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
if i do true duals, i'll be using these powersticks or dynomax ultraflo rounds
Old Jan 8, 2008 | 03:44 PM
BMAN90RS's Avatar
hey orr, how did u do the tail light mod? u know all red instead of the orange
Old Jan 9, 2008 | 12:53 AM
pg29's Avatar
Car: 88 GTA
im running hedmen longtube headers to 3 inch cats to a medium 3 inch powerstick on each side of my true dual side exit exhaust and love them, the car went from 6.9 stock, to 6.1 0-60 with just that custom exhaust me and my dad (mostly my dad) welded up. best mod we've done so far. i highly recommend the powersticks for the power, sound, and ground clearance, also cant beat that price.
Old Jan 9, 2008 | 01:39 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
That was using Testors model spray paint, Translucent Candy Apple Red. gave it 3-4 coats and it worked well
how do you like the clearance?
Old Jan 9, 2008 | 09:57 AM
Rayzor32's Avatar
Car: '89 IROC-Z
Engine: 355
Transmission: 700r4 edge 3000 stall
Axle/Gears: 9-bolt 3.73
id gut those cats too then ud get more power
Old Jan 9, 2008 | 02:43 PM
pg29's Avatar
Car: 88 GTA
the clearance is decent, i dont scrape on driveways as long as i take them slow, and i just have to go slow over speedbumps.
Old Jan 9, 2008 | 03:39 PM
Demon355's Avatar
Did you take the lens apart or did you spray the outside? If so, what did you use to clean/prep the light?
Old Jan 9, 2008 | 04:58 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
sprayed the outside...cleaned with laquer thinner but i think acetone or rubbing alcohol would work too
Old Jan 9, 2008 | 07:08 PM
BMAN90RS's Avatar
so you just taped the grids right? and everything else of course, then just 3-4 coats and thats the product? im gonna do that
Old Jan 9, 2008 | 09:34 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
yes thats all
Old Jan 9, 2008 | 11:13 PM
BMAN90RS's Avatar
is that paint available online?
Old Jan 9, 2008 | 11:28 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
probly at hobby sites and such.. i got mine at walmart in the toy/model section. any store that has models and such will have it more than likely.
92GTA
Apr 9, 2016 07:39 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
TOXIC-Z
Jul 8, 2003 11:55 PM
yesfan2000
Apr 6, 2003 11:09 PM
joatrash
Mar 30, 2003 03:46 PM
