v6 exhaust, 350 engine work?
Car: 92 25th anv camaro rs
Engine: 305 tbi
Axle/Gears: 3.08s non posi
ok im in the middle of a engine swap from a v6 fi to a 350 carb, and im just wondering will the stock exhaust work with the new motor? its factory 2 1/2" i do believe, the 350 i do believe also has headers with 2 1/2" outlet, so they should bolt right up, but would there be any problems?
Transmission: 4L80E/4L80E
Step 1 of exhaust when swapping from V6 to V8: Remove all of the V6 exhaust.
Step 2: Install something that will work.
Engine: 305 tbi
Re: v6 exhaust, 350 engine work?
lol five, as always ty for the help, but the headers that came with the v8 r the same as the v6 exhaust, so do i nd to get new headers now? and if im remove the v6 exhaust, what should back on? is it the 3" pipes i nd now...
Car: '89 IROC-Z
Engine: 355
Transmission: 700r4 edge 3000 stall
Axle/Gears: 9-bolt 3.73
what?? how are they the same wouldnt there only be 3 tubes?
Engine: 305 tbi
i have no idea, if u seen my other posts, both my new 350 and camaro r a mystery, its puzzling yes, so why wont the stock exhaust work? to small?
Car: '89 IROC-Z
Engine: 355
well yeah the pipes would be small and the y pipe would be different and headers on a v6 obviously are not going to fit a v8
Engine: 305 tbi
ya ik ik but money is a lil tight, n dont worry im not gonna ask whihc system should i get, lol, but ik the headers r different but what im sayn is the headers that came on the 350 litterly bolt right up to the stock exhaust...so i was wondering if it would work, but im guess no now, so ill look for a new exhaust
Engine: 305 tbi
ya thats wut i was thinkn, i just wanted to now if it would hurt anyhting, lik the motor, or blow a hole in something n that causes damage to something
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
it won't hurt anything, but your brand new 350 will run like the v6 you just pulled out with factory v6 exhaust.
at the very least, scour the classifieds for either HO or TPI manifolds/y pipe.
Factory V6 is 2". Some aftermarket cat-backs use 2.5", even for the V6 application.
But, no way the y-pipe would bolt up to both - unless that also is aftermarket or custom.
Engine: 305 tbi
hmmm most be aftermarket then...whihc is wierd, but then again i have come to accept that my camaro, is a puzzle in a puzzle in a puzzle
Sorry, I haven't seen your other posts. What's the 8th character of the VIN?
Engine: 305 tbi
actually five u hav, uve replyed in quite a few, n i thank you for the help, now the 8th digit in my vin is...S
