magnaflow muffs? anyone got them
Old Jan 8, 2008 | 04:20 PM
Recaro trans am's Avatar
Car: 1985 pontiac trans am
Engine: Procharged 5.7l
Transmission: t-56
Axle/Gears: stock 9 bolt 3.71
ive got a true dual set up on my 1985 trans am 2 1/2 oval exhaust pipe from a set of hooker headers all the way to over the rear axle. im gonna squese two muflers in the space next to the trunk well and the spair tire well, and the trunk well and the storage area. These mufflers part # 642-14827 will fit nicley....... well at least i think so. lol anyone use these or somthing simular? I would like to know what they sound like. and if anyone thinks it will look well wrong for the car. if i measured right they will tuck up nice and you should only see about an inch of the bottom and the tip.
Old Jan 8, 2008 | 04:36 PM
89formula350b2l's Avatar
Car: 92 Camaro
Engine: Dart SHP 406 HSR, LE heads
Transmission: Performabuilt Level 2, Vig 3200
Axle/Gears: S60 373
Re: magnaflow muffs? anyone got them
i dont have true duals, but i do have a magnaflow muffler sound clips are in signature
i looked at the muffler and its 2.25 in 4" out....sounds like it might be intended for imports.... so you want to downgrade your exhaust from dual 2.5's to dual 2.25?
Last edited by 89formula350b2l; Jan 8, 2008 at 04:39 PM. Reason: Automerged Doublepost
Old Jan 9, 2008 | 05:10 PM
jerflash's Avatar
Car: 90 Formula, 02 ws6
Engine: 305 tpi, ls1
Transmission: 700r4, t-56
Axle/Gears: stock posi 2.73, 12 bolt with 4.11s
i run only magnaflow now since i first got one on my 2002...great sound and awesome flow
Old Jan 9, 2008 | 07:13 PM
Car: 92 Camaro
Axle/Gears: S60 373
I agree with the awesome flow that the Magnaflow has, but sound is opinionated. It doesnt sound like crap, but I was looking for the Magnaflow to hide my lopiness from my cam. It did a little bit but not as much as I would've liked. And since it doesnt hide it, I would like to change to Hooker Aerochamber
Old Jan 10, 2008 | 01:35 AM
lonman89's Avatar
Car: 1985 chevy camaro IROC-Z
Engine: 5.7 litre 350 4 bolt main
Transmission: 700r w/B&M shift kit
Axle/Gears: 10 bolt w/3:42 gears
my magnaflow sounds like **** to me,it sounds great at idle and flows decent but when i go wot it sounds like **** so im gonna swap it out for a flowmaster 40 series when i put my new headers n etc on
Old Jan 10, 2008 | 04:02 PM
Transmission: t-56
Well it seems as if i have got a reall problem. I was really hopen everyone agred on the magnaflow. lol Well i had a flow master on there and i like the way it sounded but it was going into a single inlet. My other problem is i only have enough room for a 8 inch wide muff, theres only 9 inches of space at the widest point. Well if anyone knows of any good sounding small sized mufflers, let me know. straight pipes are way too loud. lol Never thought i would say that.
Old Jan 13, 2008 | 07:06 PM
acholoik's Avatar
Car: 92 camaro
Engine: 5.7 tpi
Im thinking on going with the same set up on my street car, using the magnaflows. I have a magnaflow muffler now but im not true duals. I have the magnaflow catalog and they do make that muffler in 2.5. They go for about 60 bucks a piece.
Old Jan 13, 2008 | 07:23 PM
ross's Avatar
Car: 82 camaro
Engine: 434 ci
Transmission: t400
Axle/Gears: 9'' 4.10 gear
I have a pair on my car and use them on every car I tune also thay will give you more HP. than the flowmaster. And my car has dual 3'' with an H pipe with the mufflers under the rear seats with turn downs.
Old Jan 13, 2008 | 11:44 PM
Brisk's Avatar
Car: '88 IROC-Z / '91 Z28 / '91 GTA
Engine: LT4 Hot Cam 305 / L98 355 / MR 383
Transmission: 5-spd / 700R4 / 700R4
Axle/Gears: 3:45 / 3:23 / 3:23
I can say since I've switch to magnaflow, I havn't looked back!
Old Jan 14, 2008 | 12:11 AM
Jay's Avatar
Jay
Car: 88 IROC
Engine: 5.7 RamJet
Axle/Gears: Dana44 4.10
I went with Magnaflow for my car.
http://www.youtube.com/watch?v=2LHQAwcJr_Q&feature=user
Old Jan 20, 2008 | 11:15 AM
Car: 92 Camaro
Axle/Gears: S60 373
sound in sig
FormulasOnly
Jul 23, 2018 08:47 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
