hopefully someone has tried this..
Car: 1991 Z28
Engine: SBC
I took out my blower motor/evap box to fix a rust hole forming in the fender well. Well i was planning on doing headers soon anyway so now would seem like the perfect time since i got a ton of room on that side. Question is i am installing a pair of heddman shorties i have and was wondering if after i put the headers in am i going to have the room to cram the blower motor box back in place after fixing the rust hole? I assume i will but i am hoping someone might have run into this before...
Seems exhaust RELATED..so i figured id post it here..if the post needs to be moved please do so by all means
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
Re: hopefully someone has tried this..
if you have an aftermarket oil pan, you may have to modify the y pipe.
my moroso got in the way of things.
Car: 91 RS
Axle/Gears: 10 bolt
If I remember corectly yes you can access all the bolts to get the box in and out with hedmans.
92fire-audio
Sep 5, 2001 12:10 AM
