One clogged CAT?
Old Feb 27, 2008 | 09:05 PM
ROTICKA's Avatar
Car: 1984 T/A
Engine: 5.7L TPI
One clogged CAT?
Hi again. I have an 84 T/A with an 88 5.7 TPI. I had one of the CATS replaced some months ago due to it clogging (most likely from running too rich) I have since also replaced the distributor(See previous posts). Awhile back I had to stop driving it because it was stalling and running very rough. It threw a TPS code, so I adjusted that and the code went away. It was also throwing MAF and MAF BURN OFF codes. So after a few months of sitting and saving I bought a new MAF and installed it. But that didn't solve my problem, and not only that, but I drove it to the gas station and when I got in to leave it would not shift out of first gear (700 R4) it has park, reverse, and neutral but in any of the forward gears OD, D, 1, 2 the tranny won't come out of first. I had a thought that maybe my other CAT (dual CATs)ended up clogging so bad that it's throwing my motor out of whack? Thereby causing a timing type shifting issue with the tranny? Help please I miss my car! I'll answer any questions that will help you to help me. Thank You.
Old Feb 28, 2008 | 12:26 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: One clogged CAT?
My MAF diagnosis is rusty, but if it sets the 33 and 36 MAF/Burnoff codes, that usually means the relays on the firewall are bad.
As far as the transmission issues, that sounds like the tranny is slowly dying and needs a $1000 rebuild. There is nothing in the engine that would affect the tranny, except the TV cable connected to the throttle body. That must be connected in order to provide extra pressure to the trans when you step on the throttle.
Old Mar 1, 2008 | 10:28 AM
ROTICKA's Avatar
Car: 1984 T/A
Engine: 5.7L TPI
Okay, maybe the trans needs work, maybe it doesn't. That's why I'm here. The first and only person to reply tells me to take it to the shop. That's defeating the whole purpose of this web site. I know that a faulty MAF Burn off relay, in conjunction with a NEW MAF will not cause the car to run the way it does. I also know that a mis adjusted TV cable will cause the trans to shift all kinds of funny - so why not not at all? There is nothing I could try, test or check to narrow my problem down? I have a brain and I can use it! Just give me some knowledge to put into practical application!
Old Mar 1, 2008 | 12:55 PM
TheScaryOne's Avatar
Car: 1987 IROC-Z Camaro
Engine: L98 5.7L TPI
Transmission: 700-R4
Axle/Gears: 3.27 BW
If you've lost forward gears, but park, reverse, and neutral work, then your tranny crapped itself. Take it to a shop.
The TV cable adjusts shift POINTS. If the car doesn't SHIFT, the TV cable can't adjust shift points. If PRN work, then the linkage that goes from your shifter to your tranny works, and something in the transmission has gone wrong to lose forward gears.
Edit: Oh, and if you haven't checked fluid and the like, do that. If the fluid is full, smell some. If it smells burnt, you have tranny issues.
Old Mar 4, 2008 | 12:20 PM
ROTICKA's Avatar
Car: 1984 T/A
Engine: 5.7L TPI
Well, I have one forward gear; first gear. I checked the fluid, and it's about a quarter inch above the full line with the car cold. I know you are supposed to check it hot, but, the car won't really go to get it hot. Anyway the fluid looks and smells like I just put it in there. Would a bad governor cause it to not shift?
Old Mar 4, 2008 | 01:38 PM
IROCmonkey's Avatar
Car: 85 IROC
Engine: LB9
If it is not shifting up at all, youve most likely lost the 1-2 clutch pack or a planetary. Although I suppose the shift governor might do that, I'm NOT a tranny expert.
You have 2 seperate issues. #1 is possibly blown tranny, #2 is MAF codes, check your maf connectors at the sensor and the relay. Wiggle them a bit, does it change idle? Could be a loose connection.
Old Mar 4, 2008 | 02:53 PM
ROTICKA's Avatar
Car: 1984 T/A
Engine: 5.7L TPI
thanks guys. I guess it's probably not the CAT and I should probably seek help on the transmissions/drivetrain board. I appreciate your advice.
Old Mar 4, 2008 | 09:25 PM
rawr12345's Avatar
i think i might of had the same problem with my camaro, one day my shifting got all f'd up. i could only use park reverse neutral and 1st and it turned out that my shifting cable was ripped to shreds..but never got any codes so idk
Old Mar 6, 2008 | 12:04 PM
ROTICKA's Avatar
Car: 1984 T/A
Engine: 5.7L TPI
Turns out the shifting problem was due to the gear on the shift governor being broken. Replaced the gear, shifts through all forward gears now. Thanks for your help!
Old Mar 6, 2008 | 12:07 PM
327_TPI_77_Maro's Avatar
Car: 2000 BMW M5
Yeah that cheesy plastic gear def. gets chewed up over time.
LT1Formula
Oct 8, 2015 08:34 PM
jaridjohn
Oct 5, 2015 07:01 AM
