Test Pipe
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: Test Pipe
You have to make one yourself because they're totally illegal on a street car. And Florida is getting emissions tests in the near future so you should keep your cat on there.
Car: '88 GTA
Engine: L-98
Car: '87 Iroc camaro
Re: Test Pipe
sweet awesome let me know how that goes...buyin slp headers and y pipe for 100 bucks wanted to get rid of the cat so yeah let me know how that goes
Car: 1984 T/A WS6
Engine: L69 305
Axle/Gears: fact G80 with GT4 3.73
Re: Test Pipe
imo if u are looking for a test pipe with an air tube this is prolly ur best bet. if i didn't need the air tube i would have gotten a 21" x 3" slip fit pipe at pepboys or someplace like that.it would be alot cheaper.
just so u know i do have an 84 t/a,but i'm getting the exhaust for 86 and up. so this will be ur application.
when i get everything on i will post a sound clip of the full exhaust.
Car: '88 GTA
Engine: L-98
Car: 1984 T/A WS6
Engine: L69 305
Re: Test Pipe
what catback do u have and can u please put a sound clip up????????
Car: '88 GTA
Engine: L-98
Re: Test Pipe
I do have the factory manifolds. For mine there were no gaskets/donuts needed but I believe your set up is a bit different then mine (yours being a carb car). On the pass manifold I believe you have some sort of flapper where I have a spacer, and they go inbetween the the y-pipe and the manifold. Im not familiar with your flapper set-up so I dont know if it needs any gasket. EDIT- yes its all ball/socket connections on my car
I have a 4th gen Magnaflow cat back on it but the only sound clip I have the car still has the factory Y and cat on it. No clips of the current set up, sorry. Click on the sig to see my f-quick page which has the old clip on it (which sucks)....
Re: Test Pipe
sweet...thanks again and ummm yeah can i just cap the air tube? my emissions crap is hooked up
Car: 90 Firebird Formula
Engine: LO3
Axle/Gears: 3.08 one wheel peel
Car: '88 GTA
Engine: L-98
Re: Test Pipe
Nothing drastic, but it did make difference. I should be heading to the strip on the 4th, so maybe I can come up with something more definitive then the butt dyno lol
Car: 1984 T/A WS6
Engine: L69 305
Re: Test Pipe
my air tube goin to the cat is crimped. so i bought an air tube repair kit from autozone.
Re: Test Pipe
well there isnt a belt hooked up and it looks like the pullys dont line up so i think im gunna gut it out...but knowing that the emissions test might come to FL might leave them on =/
